Methods to change lash adjusters...
Old Jul 4, 2013 | 08:27 PM
cavfiredesire's Avatar
Ive decided to upgrade to the newer style lash adjusters and followers.
I swear I read on here at one time that you can change the lash adjusters and followers without removing the cams.
If so how would I go about doing this?
Or do I Have to get the cam sprocket holder and remove the cams?
Old Jul 4, 2013 | 10:47 PM
mrbelvedere's Avatar
get the j tool or untime the engine and remove cams
Old Jul 4, 2013 | 10:57 PM
What is the "j tool"? Id rather not have to re-time the motor.
Old Jul 4, 2013 | 11:36 PM
the cam gear holding tool but my advice is don't fix what aint broken
Old Jul 5, 2013 | 12:09 AM
Cobalt_SSTuner's Avatar
Best advice I've heard...
Except when it comes to the new timing chain tensioner, that should be replaced if you have the old style lol
Old Jul 5, 2013 | 08:34 AM
I have the new style tensioner. Its not the timing set making noise. Ive spent alot of time going everything with a fine tooth comb. Mongo gave me a good deal on some LNF lash adjusters and rockers so im going to give that a shot.
Ill buy the cam tool. They are fairly cheap.
Old Jul 5, 2013 | 08:39 AM
"you don't need to pull the cams to swap out lash adjusters "
This was the quote from you in my lifter tick thread that made me wonder Mr.Belvedere
Old Jul 5, 2013 | 10:05 AM
you don't need TO if you can compress the spring and slide the follower out and you can loosen or remove cam caps to allow the cam to loosen up for some extra wiggle room
Old Jul 5, 2013 | 11:26 AM
TStone's Avatar
I'd just buy the cam gear holding tool
Old Jul 5, 2013 | 11:29 AM
if it is not broke I would not **** with it
Old Jul 5, 2013 | 10:50 PM
Its making noise in there... ive checked all the timing parts and nothing seems out of the norm, nice and tight and such, all the bolts are tight and in the right spot.....
The only place I kinda hear the noise is by the oil filter.
what do you suggest?
Old Jul 5, 2013 | 11:18 PM
Tick or knock?
Old Jul 5, 2013 | 11:22 PM
the tick could be a fuel injector If its running fine me personaly I would wait for a hard fail but that is me its your so if your froggy leap
Old Jul 5, 2013 | 11:26 PM
Powell Race Parts's Avatar
^^^ I agree. Its more likely the black tensioner guide than a lifter or rocker. The LNF rockers may contact the valve spring retainer on the exhaust side, depending what you have for retainers.
Leave it alone is good advice. check the black tensioner guide bolts before you make that froggy leap.
Old Jul 6, 2013 | 01:01 AM
^ I already did that. Bought the timing set from crate engine depot thinking it was all going to be in pieces.
Pulled it apart and everything was together and just fine. I checked the upper bolt and it was tight.
Im currently just running stock everything.
It runs just fine.
Old Jul 7, 2013 | 11:28 AM
It runs just fine.
Good buy. How you do you check the upper bolt? The torque value is 89 inch pounds; breaking (undo) torque is higher than tightening torque. Therefore, the best is to remove the bolt and replace it with new. Upgraded best. 89 inch pounds; thats not a lot. The black guide can be broken at the top, or at the bottom and makes the ticking noise you describe on start up. Its easy to see if the top of the guide is broken. Not so easy on the bottom, if at all. Good luck.
Old Jul 7, 2013 | 05:27 PM
I pulled the valve cover off and saw the top is not broken off, I pulled the timing cover and the bottom is still intact.
To check the upper bolt I took the cover off and put the torque wrench on it. It clicked right away and was not broken or loose. The guide did not move at all.
I listened with a screwdriver for the noise at many parts of the motor all around the timing set and it did not sound like it was coming from any part around the timing set.
Unless the LNF timing tensioner I got is no good.
Since this is actually on a cav with a 2.2 the lifters I have read is a common thing to go bad.
Old Jul 9, 2013 | 07:43 PM
Another thought..
How can we tell if the balance shaft tensioner is bad?
Old Jul 9, 2013 | 08:00 PM
Tjolley's Avatar
Change it lol.
Never hurd of one goin bad.
Old Jul 9, 2013 | 08:15 PM
Another thought..
the accessory chain will rattle and some have been replaced
Old Jul 10, 2013 | 08:20 PM
I noticed when I took my timing stuff apart that the accessory chain does have a fair bit of slack in it. I checked my other motor and it was the same way. Is this normal?
I assumed from the design of the tensioner that it is simply oil driven and uses the racheting mechanism to hold its place.
Old Jul 10, 2013 | 10:59 PM
it has a ratcheting mech to help hold it In place and is oil driven but can get weak and bypass internaly
Old Jul 10, 2013 | 11:08 PM
c130aviator's Avatar
I have had to pull my timing stuff several times for noises, mine ended up being a broken bolt. My accessory chain had some slack in it as well, I have no noises now except for the loud injectors that is common to the ecotec.
Old Jul 11, 2013 | 08:40 AM
Ive got a few cam and crank bolts on order so I can do just that. Its driving me nuts and its gotten worse.
I may grab a new exhaust manifold gasket and change that, as well as new springs for my Pacesetter ball socket. Dont think its that but it helps eliminate stuff.
I just cant pinpoint where its coming from . Even with a screwdriver on the timing cover I didnt hear the tick there. The only place was by the oil filter.
This thread has derailed a bit, but I have ordered the cam holder tool and a good set of lifters from Mongo off a LNF.
Worse case something fails. Id rather it not though since its my DD. New motor being built this winter.
Old Jul 11, 2013 | 10:38 PM
After playing with the engine revs a bit today I noticed a pattern.
It seems to tick at 1500 rpm with little engine load, but goes away if I raise or lower the rpms....
It seems to be very consistent with 1500 rpm.
Any thoughts?
