Miles per gallon questions
Old Feb 22, 2009 | 12:58 AM
policeoff1's Avatar
I have a quick question I use to get around 26-27 miles per gallon with my car, well i installed a AEM cold air intake and needed new tires so i bought new cooper tires. Well a few months down the road started to notice that now I'm only getting 21 mpg.
I needed an oil change so I assumed that was my problem so I got that changed and reset my MPG gauge and it went back to about 21 MPG is this normal?
or did the new cooper tires be responible for the 6 mpg drop
Old Feb 22, 2009 | 01:02 AM
Acey's Avatar
I'm gonna go ahead and say that tires wouldn't cost you 6 mpg.
Old Feb 22, 2009 | 01:05 AM
policeoff1's Avatar
do you have any idea why i would be at 21 mpg i hear ppl talking they get 27-32 mpg with a stage 2 kit.
I had to drive it in the winter could my cold air intake be dirty its got about 3,000 miles on it
Old Feb 22, 2009 | 01:06 AM
myfakeevo's Avatar
are they snow tires? cause it is possible that the tires have decreased your mpg. all companies make tires that perform for fuel efficiency, that is why they are getting such great gas milage. I also am averaging above 27mpg and have an intake on thru winter.
Old Feb 22, 2009 | 01:10 AM
policeoff1's Avatar
no there all season tires, i did notice they raised the car a bit, there alittle bit thicker then the parelli's were
Old Feb 22, 2009 | 01:12 AM
XxDHiLLxX's Avatar
That's weird Maybe filter or cat is clogged?
Old Feb 22, 2009 | 01:14 AM
policeoff1's Avatar
i just got the oil filter changed and this spring i will pull out my cold air intake to see if thats dirty
the exhaust seems to be normal doesnt seem to be clogged but im no expert. It doesnt seem to be bogged down the acceleration is there pretty good
Old Feb 22, 2009 | 01:39 AM
XxDHiLLxX's Avatar
thats really strange maybe try resetting your computer?
Old Feb 22, 2009 | 01:41 AM
D4u2s0t's Avatar
winter mix of gas will give worse mileage than in the summer. possible that could be the reason. how often do you reset the dic? or are you manually calculating.
Old Feb 22, 2009 | 01:42 AM
BLAZIN07SS's Avatar
I'm too JDM for you
winter blended gas. /thread
damn i got beat. lol
Last edited by BLAZIN07SS; Feb 22, 2009 at 01:42 AM. Reason: Automerged Doublepost
Old Feb 22, 2009 | 08:28 AM
myfakeevo's Avatar
just to clarify, no matter how bad your oil gets it will never give you bad gas mileage.
and yes winter gas mix is very plausible
Old Feb 22, 2009 | 09:30 AM
My06ss's Avatar
I get 26-27 with the shitty winter gas around town & 29 on highway, in the summer when gas is back to normal I average about 28 mpg's around town & 30-35 on highway, but then again I dont drive my car that hard all the time just the occasional highway pull, I get great MPG"s especially with the mod's I have, there is no reason that you should be getting such bad MPG's, try disconnecting your battery for about 10min so that it can reset the computer see if that works, also are you calculating your mpg's at the pump ? or are you just going of the cars DIC which is rarely correct.
bigdeertz
Nov 17, 2016 09:41 AM
brandon04
Oct 21, 2015 07:04 AM
HEATON
Oct 16, 2015 07:21 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
