Modification List?
Old Oct 21, 2007 | 11:15 AM
galeblanc's Avatar
Modification List?
Hi,
Can someone post a list of mod's in a particular order of what could be done on a ss/sc. I think this would be valuable information for many people here on the site. Let's say start with a stock ss/sc. I imagine the stage 2 would be the first mod and then???
Your help would be greatly appreciated.
Thanks in advance,
Gabriel
Old Oct 21, 2007 | 11:32 AM
07 SS/SC's Avatar
This list is going to be insanly long. Do you want just performance parts? Or are we supposed to include appearence mods and all that other jazz?
There are a million different ways to mod your car, you dont have to go in a particular order.
Old Oct 21, 2007 | 11:35 AM
galeblanc's Avatar
Nope, only the performance. A basic list. I don't plan on going up to 300 HP or anything like that. From what I know, the ingalls engine damper, the exhaust, stage 2, cold air intake, are the basic mod's. I just want the basics. Am I missing anything obvious?
Thanks
Old Oct 21, 2007 | 11:36 AM
BlilBT's Avatar
Here are some of the Mod's you can do!
Old Oct 21, 2007 | 11:40 AM
galeblanc's Avatar
Thanks, that looks amazing!! Is it in some kind of order, or, is it just a list in random order. (For each section that is)?
ps. Where did you get that? Is there a site/link?
Old Oct 21, 2007 | 11:42 AM
galeblanc's Avatar
Originally Posted by Blurred Vision
Stock tune upgrades
air box mod
3.1 pulley
custom dual pass
header
custom exhaust
clutch
lightweight flywheel
1 step colder plugs
motor/trans mounts
torque dampner
Thanks, you guys are so helpful!! This is exactly what I wanted to know. Now I can go look for parts.
Old Oct 21, 2007 | 11:54 AM
Blurred Vision's Avatar
Stock tune upgrades
air box mod
3.1 pulley
custom dual pass
header
custom exhaust
clutch
1 step colder plugs
motor/trans mounts
torque dampner
Custom tune
2.7 or 2.8 pulley
oversize tensioner pulley
60# injectors and harness
1 step colder plugs
CAI
header
3" exhaust with or without cat
motor/trans mounts
torque dampner
meth injection
clutch
lighter flywheel
aftermarket heat exchanger
dual pass intercooler
surge tank
Custom tune and internals
2.7 or 2.8 pulley
1 step colder plugs
CAI
header
motor/trans mounts
torque dampner
meth injection
clutch
lighter flywheel
surge tank
diamond 10:1 pistons
JBP connecting rods
JBP cams
ferrara 1+ valves and springs
JBP ported and polished head
GM neutral balance shafts
GM adjustable cam gears
Darton sleeves
Drag radials
Custom tune and internals and turbo
super 60 t3/t4 turbo
turbo manifold
large front mount
custom charge piping
external waste gate
blow off valve
boost controller
Saab turbo intake manifold
co2 spray bar kit
1 step colder plugs
motor/trans mounts
torque dampner
clutch
lighter flywheel
diamond 8:1 pistons
JBP connecting rods
JBP cams
Darton sleeves
Drag radials
Last edited by Blurred Vision; Oct 21, 2007 at 12:20 PM. Reason: Automerged Doublepost
Old Oct 21, 2007 | 11:59 AM
nich7601's Avatar
If you don't want insane HP, just a little boost, I would go with
CAI
Exhaust
Header/DP
Stage 2
Pulley
HPTuners
Old Oct 21, 2007 | 12:02 PM
nich7601's Avatar
Old Oct 21, 2007 | 12:03 PM
BlilBT's Avatar
I made it in Photo shop & Order is Performance, Visual, & so on!
The 1st thing I bought was stage 2 & GM performance Exhaust!
Old Oct 21, 2007 | 12:05 PM
Hi,
Thanks in advance,
Gabriel
Read a little better bud!
Originally Posted by nich7601
ok man
Last edited by Blurred Vision; Oct 21, 2007 at 12:05 PM. Reason: Automerged Doublepost
Old Oct 21, 2007 | 12:07 PM
FryLoch's Avatar
stage 2
honed manifold
gmpp sport exhaust
injen cai....well it's still in the box right now till I get my new supercharger....
Old Oct 21, 2007 | 12:09 PM
Originally Posted by SS07
stage 2
honed manifold
gmpp sport exhaust
whats wrong with the supercharger u got
Old Oct 21, 2007 | 12:16 PM
Admiral Jedi's Avatar
Depends how crazy you want to go with the car.
If I had one:
Motor Mounts
Transmission Mounts
Intake
Header back 2.5" longtube exhaust
Stage 2 with a 2.9" pulley
Port the Supercharger
Dual Pass Mod
Scan Gauge
Screw that HPTuners crap, lol.
That's IF you want to stay supercharged.
A Solstice GXP turbo would be a nice upgrade.
Old Oct 21, 2007 | 12:23 PM
galeblanc's Avatar
I currently have the stage 2, and I think the GM Exhaust is my next mod. Then the engine damper ingalls or the engine mounts + tranny mounts. I am looking for info as to what's best. From what I read, the motor mounts make a knocking noise. And then the ingalls break in the long term. So I don't know what to do for now.
The wheel hop is annoying and I really need to get rid of that. Certainly in the rain, it's even worse. So, tranny mounts and engine mounts will solve this? Or the ingalls are a better option? What do you guys think?
Old Oct 21, 2007 | 12:35 PM
BlilBT's Avatar
I have had my Ingalls for 1 1/2 years & no problems, You might want to think about better & Lighter rims & Motor mounts just make Vibrations a little stronger! you can feel the difference with the Ingalls & anything will break after being abused to long even Motor mounts over time will go bad depending on abuse! But they both are a great combo together
Old Oct 21, 2007 | 12:43 PM
galeblanc's Avatar
So you're recommending the ingalls damper and the motor mounts? Do you think the dealer will install these to avoid warranty issues?
Old Oct 21, 2007 | 12:45 PM
BlilBT's Avatar
The Ingalls only reguires a 14 mm I think been a while, The Motor Mounts just reguire a Jack & a Few wrenchs. I dont believe the dealer will install aftermarket parts!
Old Oct 21, 2007 | 12:46 PM
supercharged414's Avatar
depending on how much you're planning on modding your SS/SC, stage 2 isn't worth it. You're going to spend all that money and then (like i did) you're probably going to drop down to a smaller pulley (like a 2.7). then you should get 60# injectors, a tensioner, a retune, and 1 step cooler plugs. then the only thing you're going to get to use from stage 2 is the belt, which is pretty cheap by itself. that's one mistake i made so i'm just trying to put it out there...
Old Oct 21, 2007 | 01:00 PM
BlilBT's Avatar
Ditto>> I made same mistake when it 1st came out, Then 2 months later HP Tuners came out & I bought that. So in affect I bought it 2 times, But the HP Tuners has paid for them both Now!
Old Oct 21, 2007 | 01:11 PM
ggarcia86's Avatar
intake, full exhaust with aftermarket header and downpipe, then new era performance for $400 2.8"pulley and hub, 60lb injectors and custom tune, and be at about 270whp
patooyee
Oct 15, 2015 05:11 PM
SSLOW06
Oct 1, 2015 07:21 PM
dieGone
Oct 1, 2015 06:27 PM
nathan112i
Sep 30, 2015 07:12 PM
