More test results for you guys. Want more HP?
Well for the past couple of trips to the track i have been testing a couple of things on my Cobalt so i thought i would share them with you and change the mood of post:twothumbs
#1) I have switched to an LT1 MAFF and a 3.5"id air inlet hose and a 9" K&N. Results were promising, i picked up 2mph in the 1/8th and 1.5 in the 1/4. Unfortunately, the added power has made me REDUCE the boost in 1st gear via HPTuners to allow me to hook up, somewhat! This had not allowed an improvement in ET's but with traction on a prepped track or thru better tires, 12.5 or 12.6 is a reality. The car feels incredible from any speed! SC whine is deafning! Consistent 109 trap now which is nice. Oh yea, i have 90.00 in the intake set-up!:cool: #2) I added a second stock heat exchanger mounted in front of the ac condensor and hooked up in series with the orginal unit. I saw a 15-20 degree drop in IAT2 which allows me to run more timing on my pump gas tune which is nice on the street. I feel that adding a resvoir and bigger pump, a 40-50 degree drop could be realized. That's it for now, i won't be able to race for awhile as i need new rims and tires and can't afford them but if i come accross any more good HP mod's i'll pass them on to you.:twothumbs Rob |
I WANT A WORKING CLUTCH LOL!!!! ;)
Glad to see those worked for ya...you and jamie just got me by a lil on the hwy Dan |
Where did you find the pipe? would love to make my own CAI. did you use any part of the stock box?
so ur keeping the car huh!!!!!!!!!!
Personal issues or business issues?
Very nice. Hope all works well for you and your family. I would really like to see you continue your power pioneering.
Ive already got my intake mocked up , I just need to get down there to indy to have ya do the tuning needed to except the new maf . I knew Id have a use again someday for my old spare LT1 maf :)
Were you able to find a used heat exchanger ? Ive tried looking with no luck as of yet . Its pretty pricey thru the dealer , even with my discount :( |
Were you able to find a used heat exchanger ? Ive tried looking with no luck as of yet . Its pretty pricey thru the dealer , even with my discount :( Rob |
Rob....Thanks, a ton...:twothumbs
Wow..... Thanks for the info. Next time you go to the track, PM me..I'd like to come over and watch you run. I assume you are going to IRP?
Dang it, i was about to add a 26" X 8" X 3" water intercooler for mine before i sold it but i lost steam in doing so because no one thought it would be worh while, I should have known better.
Rob, have you considered Water/Meth injection to your tune yet?
Rob, any issues with the Spec Stage 3+ clutch in relation to what people have found out about our master/slave cylinders, etc.?
what is involved into converting to LT1 maf? any reprogramming or just a straight plug and play (I would asssume you have to reprogram...)
