Mounts!!!
Old Aug 11, 2008 | 02:35 PM
07touringcoupe's Avatar
Mounts!!!
How many engine and tranny mounts are there? How do they look? Where are they? The reason i ask is cuz i got a 07 SS s/c used and i can feel vibrations at low speeds on the highway on really smooth road and sometimes when im at a light i can feel the car vibrating. I need to find out if their are already aftermarket mounts on there.
Old Aug 11, 2008 | 02:51 PM
Werewolf SS's Avatar
Mounts are as follows:
Engine mount (1)
under hood on left side (passenger) easily seen.
Tranny mounts (3)
One in front of tranny bottom of car
Second is rear of Tranny bottom of car
Third is under hood beneath fuse box.
Old Aug 11, 2008 | 03:33 PM
Engine mount (1)
Tranny mounts (3)
What do the aftermarket ones look like? Where can i get em from?
Old Aug 11, 2008 | 03:35 PM
NinjaHampster's Avatar
Turbo Tech Racing which is a vendor on here. you can get the poly urethane ones and they eliminate wheel hop
Old Aug 11, 2008 | 03:44 PM
Those are inserts right? They they make the whole mount? Are the inserts hard to put on or in? When i was looking i only saw one set of tranny mounts. Are all the mounts the same size?
Old Aug 11, 2008 | 04:28 PM
arkkornkid's Avatar
yeah, they're just inserts but really easy to install. just remove the whole mount, put in a vise, get a large screwdriver between the mount and plastic sleeve and it'll pop right out. then with the center metal tube (can't remember what it's called now,,,duh) out of the new insert, grease it all around, wedge it in the mount as best you can and hit the high end with a hammer and it'll go right into the mount...no problem.
The 2 lower mounts are the same size, I don't know about the upper one under the fuse box.
Old Aug 11, 2008 | 05:19 PM
oh iight thats cool. How long do those mount last? Cuz i heard they crack over time!
Old Aug 11, 2008 | 05:48 PM
arkkornkid's Avatar
not sure, but my understanding is that polyurethane is much more durable than rubber, so I'd assume they'll last for a good long time, had mine in for about 5,000 miles and was under the ride yesterday installing my twin subframe bar and they looked just like the day I put them on.
Old Aug 11, 2008 | 06:10 PM
TurboTechRacing's Avatar
Check out www.TurboTechRacing.com we have the best rated solid mounts on the market.
Old Aug 11, 2008 | 07:25 PM
another thing. I dont have a vise. Is there another way that i can get the old insert out?
Old Aug 11, 2008 | 08:00 PM
A rubber hammer, strong hands and some lube Or visit a friend that has a vise
Old Aug 11, 2008 | 08:06 PM
scampbell's Avatar
hey guys will tranny mounts with an ingalls work just as good as tranny mounts and a solid engine mount?? im thinkin about gettin the tranny inserts from ttr..
Old Aug 11, 2008 | 08:13 PM
Yes they will work well, however just keep in mind that a solid upper mount has been proven to be better(by those who had the Ingalls and then when to the TTR Mount).
Old Aug 11, 2008 | 08:46 PM
scampbell's Avatar
im just solid mounts on the tranny and engine might cause too much vibration.... but the added traction might be worth it.
Old Aug 11, 2008 | 08:54 PM
auggie_ss_phx's Avatar
same size and really eazy to do here is what the stock and the ttr one
TTR
Lube? What like WD40
Old Aug 11, 2008 | 08:56 PM
thats what i used and a 2x4 and i got on top of the 2x4 to press the mount in and it work
Old Aug 11, 2008 | 09:54 PM
Yeah they install pretty easy.
Old Aug 11, 2008 | 10:35 PM
also if you want to try putting them in the freezer for a couple hours and then moving fast hammer them in. freezing makes it smaller
Old Aug 11, 2008 | 10:38 PM
But it will make them harder.... I still think the easiest is a little lube and a rubber mallet if you dont have a vice Whatever works best I guess...
Old Aug 11, 2008 | 10:55 PM
Silv3r's Avatar
So TTR fabricates the one visible motor mount on the passenger side of the engine bay, and the two lower tranny mounts? What about the one under the fusebox, and are there other motor mounts?
Old Aug 12, 2008 | 11:39 AM
The fuse box one is the last one, which no one makes "yet" we will look into this and see if we can get a new product released (most likely next year)
Old Aug 12, 2008 | 02:11 PM
TTR
oh ok. So before i buy mounts i should get my lazy ass under the car and find out if there are aftermarket ones there!
Old Aug 12, 2008 | 02:26 PM
That might be a good idea
Old Aug 12, 2008 | 02:34 PM
WickedSS2005's Avatar
Any special pricing on ordering all the mounts together as a package??
