mounts
mounts
Hey guys I hae reli bad wheel hop issues and I want to redo all the mounts in my 06 lsj. I don't know how many there are but I want to change all of them to kick wheel hops ass. What shud I get? Again I need every single mount! Thanks
ott stage 2 mounts if you dont want vibs ttr solid engine mount and polly trans mounts if you dont care about vibs i have had both and solid mount work a little better but i still dont get wheel hop with the ott mounts
i have the OTTP stage 2 rotated tranny mounts.... the ABSOLUTELY WORK! i have no wheel hop what-so-ever. the only time i ever get vibes with these mounts is when i turn the a/c on max and even then.... it's barely anything.
the stage 1 mount just replaces the front tranny mount
the stage 2 mounts replace both front and rear tranny mounts (i suggest these)
they rotate the transmission just enough to correctly realign the axles, eliminating wheel hop.
But now what mounts do I use for the motor. The one ontop when you pop the hood as well as any lower ones there may be?
Also do the ottp stage 2 mounts completely get rid of wheel hop on the street, track and with drag radials?
Last edited by 06cobalt_ss; Sep 10, 2009 at 01:55 PM. Reason: Automerged Doublepost
there are 3 mounts with the engine & tranny. the top one you see when you pop the hood is the only one connected directly to the engine, replacing the stock one with a solid one will cause alot of unwanted vibes throughout the cabin of the vehicle.
the OTTP stage 2 mounts replace the 2 mounts connected to the transmission and when installed correctly cause absolutely no vibes.
i have found that they do completely eliminate wheel hop on the street, track and when i use my DRs.
Perfect so ottp stage 2 it is. But I reli wanna do a motor mount this way I can get the absolute most power from my set up. I don't care about vibs I don't kno about your cars but my car is no where near comfortable to drive on the streets of ny. Lol we have pot holes that will rip your wheel off the car. I need a motor mount what u guys suggest?
maybe, maybe not. i really believe these are all anyone would need. but i do know of some people that have either a solid engine mount or ingalls torque dampener with it.
https://www.cobaltss.net/forums/parts-66/ottp-rotated-trans-mounts-187917/
buy these.... he is a good friend of mine and this a great deal
This is gonna sound kinda weird n stupid but I also kinda want a lil vib in the cabin (it pisses my gf off n gets that bitch out of my car)she can't stand the speed n noise lol it works
Well its true!!
That's y I figured I'd get a solid motor mount to add vibs n the ottp tranny mounts to combat wheel hop. Would my theory work?
Last edited by 06cobalt_ss; Sep 10, 2009 at 03:09 PM. Reason: Automerged Doublepost
it could.... but it would be a waste of money... honestly... you really need to think about if doing something unneccesary to your car just to **** someone off is really a smart idea.... use a little common sense...
Im not sure if the solid mount would work with the rotated mounts anyway.
