MP90, TVS 1900 or just turbo?
Hey all. I would like to stay supercharged even though i understand turbo is cheaper for more power. But im wondering in order to run the MP90 or TVS1900 whats required? Just the standard injectors, pulley, belt, custom adapter plate?, and a tune? Are there any companies that make this as a kit for our cars or we looking more custom at this point?
In the end is it just not even worth the hassle? Just go turbo?
A TVS bolts right on. You would need 80s, pulley, belt, cooling mods (h/e), possibly meth, and definitely a tune...And as far as $$$, a turbo is more expensive than a TVS.
ZZPerformance - LSJ Turbo Complete Swap Kit #ZZ-LSJTSWP
OTT Stage 3 Kit
And also, depends on the power and money you want to spend. TVS and such is around $2500 + you'll want to get another tune, not this canned tune. A turbo will run you anywhere from $4,000-$5,000 + another tune as well. So basically $$$$
OTT Stage 3 Kit
Btw... that 370hp from the article is @ the CRANK
but is the 1320 efficient enough to get to the 370 even at crank without really straining the motor and everything else? i understand no matter what its more strain then stock im just referring to is it like if i ran a 2.5 on stock blower that its so harmful and inefficient that it doesnt make sense?
I'm the proud expecting poppy of a euthanasia fabbed MP-90 kit, can't wait!
Ati sc balancer and euthanasia ported head on a zzp forged LE5 short block, cams, all the fixings, hoping for an easy, easy 340ish on a nice dd mellow tune.
MP90 is sort of fail. Here it is vs a pretty basic E85 2.9" TVS setup.
Red - Me
Blue - Him
The TVS 1320 would be considered an M82 as compared to a M62 or M90. But it is way more efficient.
Twin Vortex Series or bust!
Red - Me
Blue - Him
Diff dyno
I had 16-18* advance in the midrange
24 on the top
Eric is right though, better off geting a tvs if you ca. The mp90 if purchased cheap is a great upgrade over stock
24 on the top
On methanol all 4 fourth gear pulls on the dyno do not exceed 135 degrees F. IAT2 w/ a starting point of 100* iat1 in 65-70* weather
I may still have the logs... if I have time I'll see what I can find.
