MSD Ignition??
Old Jan 9, 2006 | 03:48 AM
SwizzDSMSS's Avatar
MSD Ignition??
Anyone have one yet on there SS? My buddy was telling me it is a must have. He had one on his Saleen and he noticed alot better power thru his acceleration. So what is the deal with um?
Old Jan 9, 2006 | 08:21 AM
selfinfliction's Avatar
they're not going to make much of a difference on the ss unless you're 400hp+. we have a damn good ignition system with the coil packs on each spark plug
Old Jan 9, 2006 | 11:09 AM
codyss's Avatar
On most performance cars today the ignition is damn good. Unless a more/less agressive curve is needed or they have like 500 HP you don't need it.
Most of the difference that he is feeling is due to weight reduction in his wallet.
Old Jan 9, 2006 | 11:14 AM
Brian MP5T's Avatar
It would be "Bling Bling" only... until you start breaking Trannys with HP. Then it might do something...
Old Jan 9, 2006 | 12:18 PM
Sinisterredlines's Avatar
Well to start none of the msd dis controllers will work per msd at sema. When I asked, I was told our ignitions are similar to the lsi coil on plug that has a firing module in each coil. Where as older dis systems the module is seperate from the coil.
Old Jan 10, 2006 | 02:46 PM
Ramps's Avatar
The only thing you might notice with the MSD is smoother idle and very slightly faster reving...no extra HP though. You would use a DIS 4 system. (4 coil packs)
Old Jan 10, 2006 | 09:03 PM
NO the dis 4 will not work due to the control modules in the coil pack vs standard dis where the module is seperate. This comes from the engineer at sema.
Old Jan 10, 2006 | 09:19 PM
Cobalt_Supercharged's Avatar
Damn, that sucks. The nice thing about the MSD, is that you can set the rev limit with the ignition just before the fuel cut off, and have it sit at the red line, rather than drop a bunch of rpm's because of the fuel cut off.
ricklovin93
Aug 27, 2016 06:35 PM
Shanman
ZZ Performance
43
Aug 26, 2016 08:43 PM
satisfied
Oct 19, 2015 12:35 AM
Cptnslo
Sep 24, 2015 09:32 AM
Wind
Sep 11, 2015 06:57 PM
