NBS's Necessary for 8k??
Old 02-19-2010, 07:32 PM
Maxim_X's Avatar
Along with other changes I plan to rev higher this season. I'm am installing valve springs to avoid the float. But, I've heard that GM recommends changing the balance shafts to neutral balance shafts for operation over 7500 RPM. Apparently because they are oddly weighted and spin twice engine speed they may explode when they see revs to high. Right now my motor is stock. I plan on building it after it blows, and I plan to install them then. It's kinda a pain in the dick to change them out with the motor in the car compared to out of the car. But, I would hate for the blown motor to be due to a balance shaft explosion.
So, I'm wondering who is running higher than 7500 with out them? And, does anyone know of a specific instance when they have failed.?
Old 02-19-2010, 07:59 PM
selfinfliction's Avatar
no reason to rev that high, make more power lower and save your engine
as for the float, the gm engineer told me years ago right when the stage kits were released that resonance happens at 6850rpm on the stock system, but GM wasn't concerned with it because it was such a small amount of time that the engine was from 6850-7000.
Old 02-19-2010, 08:13 PM
Chase0224's Avatar
with a tvs, or some turbos there is.
Old 02-19-2010, 08:21 PM
Maxim_X's Avatar
There is reason to rev that high. Specifically avoiding a shift in the 1/4. With 26" tires in third @ 7400 my car will do about 118.5... too slow. 500 more RPM's would bring it to about 128 which would be perfect.
Old 02-19-2010, 08:25 PM
hey sorry i thought your post was NVS meaning new valve springs, not neutral balance shafts lol
whiskey is getting to me tonight haha
Old 02-19-2010, 08:32 PM
Chase0224's Avatar
I know youve got a race car and know what youre talking about, but just a reminder, youre gonna get a **** ton of vibes.
Old 02-19-2010, 10:06 PM
Rent me! per hour
Area47's Avatar
the tvs makes peak power above 7200+ rpms and will hold it till 8k.
i run mine to 8k sometimes. not a lot. sustained 7500+ rpms will result in broken parts. one gear pull to 8k is not sustained.
Old 02-20-2010, 03:14 AM
elite_Cyborg's Avatar
anyone know what you torque the bolt that holds the gear to the shaft down to?
41 ft/lbs
Last edited by elite_Cyborg; 02-20-2010 at 03:14 AM. Reason: Automerged Doublepost
Old 02-20-2010, 04:26 AM
Maxim_X's Avatar
Sustained as is running on the limiter?
Do you know of any that have broken specifically?
Old 02-20-2010, 05:05 AM
jimbos'ss's Avatar
like area i rev the **** out of my car but only once in a while, mostly cause my turbo is far more efficient at the higher rpm range. in other words i get a lot of lag lol. on a serious note i use neutral balance shafts and the vibes aren't that bad. and its not that hard to pull the motor out.
Old 02-20-2010, 06:05 AM
OneCOLDBIZL272's Avatar
A Tvs or converted to turbo lsj will make power over 7,000rpm to 8,000rpms if the tuning is there to back it up. I have a built motor and Iv been to 8k but I backed down to a 7,700 allowing me to hit 7,500 if I want to and not bounce off the limiter, only time I'll run 8k is dyno or track to save on my motor. There's really no need to on the street In My opinion, note I have my balance shafts deleted. Vibes are noticable. I would say do them, or get rid of them like I did it your call just concider them. It's better to be safe than sorry in my book. Just my .002 cents
Old 02-20-2010, 09:52 PM
Rent me! per hour
Area47's Avatar
41 ft/lbs
make sure that gear sits flush against the end of the shaft with the bolt in there. you may have to shorten the bolt to get it set right.
i have had zero problems running to 8k every now and then. keep in mind, my car rarely see's anything above 10psi, or 4500 rpms on a daily basis. i hit 8k on the dyno, and the top of second at the drag strip.
normally i shift at 7600 when the overspeed light comes on.
Old 02-20-2010, 10:54 PM
Maxim_X's Avatar
I'm still undecided. The lack of specific examples of failure makes me want to think they can handle it. I'm only going to rev that high when I'm drag racing @ the top of third. But, that might be 150 times this year.
I'm leaning towards what I'm doing with the rest of the motor, beatin' it and hoping it doesn't break, and build when it does.
Old 02-20-2010, 11:02 PM
Dennisscars's Avatar
I've got the Bates bitchin' billet balance shafts, they are too pretty to grenade..
freakta
05-31-2012 10:11 PM
copson20
Mid Central
09-03-2008 11:37 PM
Quick Reply: NBS's Necessary for 8k??
