need assistance with meth install
Old Jun 25, 2009 | 01:44 PM
MP Cobalt's Avatar
Like the title says. I been looking for the How To for install meth injection, but I haven't found one. Does anyone know if anyone made a how to for it or if anyone had pictures of there install so i know i get everything right.
Old Mar 4, 2010 | 03:51 PM
2006RedCobaltSS's Avatar
Bump! Also having problems with my setup
Old Mar 4, 2010 | 05:13 PM
MP Cobalt's Avatar
it's real easy after i figured it out. what you need help with?
Old Mar 4, 2010 | 05:16 PM
sundevil07's Avatar
i would like to see a how to on this also, for future reference
Old Mar 4, 2010 | 05:20 PM
MP Cobalt's Avatar
I'd do a how to but, mines, already installed
Old Mar 4, 2010 | 05:25 PM
Well I ran a hose to the washer fluid tank to the pump, then I ran a hose to a T fitting on the vacuum hose off the manifold, ran the hose from the pump to the nozzle in the intake, grounded the pump and ran power off the fusebox. It's not working and I realized there is another prong on the pump that needs a connector. Where should that go?
Old Mar 4, 2010 | 05:26 PM
MP Cobalt's Avatar
Which company you have. You have any pictures?
Old Mar 4, 2010 | 05:34 PM
AIS Stage 1. No pictures
Old Mar 4, 2010 | 05:36 PM
MP Cobalt's Avatar
well my pump has two lines and the power and ground wires and all the other electical stuff. Which fuse did you jump in the fuse box?
Old Mar 4, 2010 | 05:41 PM
I think the on star fuse, but I don't have on star. Is there a way to know if your pump is on or not?
Old Mar 4, 2010 | 05:43 PM
MP Cobalt's Avatar
you can hook up an LED light and run it into your interior and when you pump kicks on depends what psi you have it to kick on at the light will light up. Try the heated seat fuse
Is that in the inside fuse box or the one in the engine? I don't have heated seats either haha
Old Mar 4, 2010 | 05:56 PM
MP Cobalt's Avatar
it's under the hood
Old Mar 4, 2010 | 05:58 PM
it's under the hood
Ok, so once everything is hooked up and done, I'm good to go? Or do I need to prime the system? And if so, how do I do that? Also, thanks for helping out.
Old Mar 4, 2010 | 06:01 PM
MP Cobalt's Avatar
no once you hook it up it should work. thats it all your wires are correct. Once i was done and took it for a ride I could smell the meth burnt through my exhaust. lol
Old Mar 4, 2010 | 06:07 PM
Ok, I'm going to go give it a try.. They're 3 prongs on the setup, the first one I skipped because there was nothing on it when I received it. 2nd prong I hooked the power up to, and 3rd I believe is from the back of the pump. Will up date shortly.
Old Mar 4, 2010 | 06:10 PM
MP Cobalt's Avatar
Get a picture also, I'm trying to think what prongs your talking about
Old Mar 4, 2010 | 06:22 PM
Ok, went for a drive, still can't tell if it's working or not. I'm on a stock tune and AFR's dip into the 10's and WOT around 4000 rpms but climb back up to 11.6ish..
Old Mar 4, 2010 | 06:26 PM
sundevil07's Avatar
11.6 on stock tune? thats pretty lean for a stock tune
Old Mar 4, 2010 | 06:35 PM
the one to the right is the power and there are 2 prongs to the left. one gets connected to the back, dont know what the other is. The one in front is the only one i have connected, don't know what the other is for
3" intake, ported head, 10:1 piston all might have something to do with it also
Last edited by 2006RedCobaltSS; Mar 4, 2010 at 06:35 PM. Reason: Automerged Doublepost
Old Mar 4, 2010 | 06:39 PM
MP Cobalt's Avatar
you talking about those prongs at the bottom? Like bannana plugs or something? Mine has two, and they get plugged together
sundevil07's Avatar
Originally Posted by 2006RedCobaltSS
[IMG]3" intake, ported head, 10:1 piston all might have something to do with it also
lol makes more sense now
Old Mar 4, 2010 | 06:40 PM
I'm going to need a picture of them together. Got lost now haha. Sorry
Old Mar 4, 2010 | 06:43 PM
MP Cobalt's Avatar
haha im in class right now. I'll try to get one,but it will be dark. Is that what your talking about though the two plugs at the bottom of the pump and the two lines come out on the side?
Old Mar 4, 2010 | 06:49 PM
these 2 prongs I have circled
