need help
need help
ok so i plan on running a 75 wet shot.. i can run that on a stock ss/sc rite?? o i have a cai.. now can i just order a universal nitrous kit or does it have 2 be for a cobalt?? and also what all do i need?? ive searched and searched and honestly couldnt really answer my question..thanks
i wouldnt run nitrous, not worth it unless your big into drag racing (on the track). best thing i could recomend is a gm stage 2 kit, gives you about 35hp more all the time, not just when the bottle is on. then go with a heat exchanger and smaller pulley and you will have more power all the time than you would actualy see with the nitrous, and you dont have to keep spending $70+ to fill that bottle up.
if you must run nitrous, the only way id do it is by running the gm stage 3 kit. it has a nitrous controller built into the pcm to run a 50hp dry shot. it will put you right around 300hp, however requires the stage 3 pcm and 42lb injectors, and a dry nitrous kit to do it this way.
