Need Help
Old Jan 27, 2007 | 10:37 PM
hatrickstu's Avatar
Need Help
Ok guys i know quite a few people are running aftermarket DP's in here and i recently put on my vibrant 2.5'' catless DP. I bought it used and it came with the gasket that mounts between the DP and the "catback." I noticed it looked like the gasket had been leaking on one side of it and checked out the DP to see if i could find the problem. It looked like the flange was not mounted as straight as it should be, like instead of being at a 90 degree angle angle it was like 100 degrees or so. I took this into account when mounting the pipe up on the car and held both pipes up in order to try and get the best fitment possible. I tightened the two pipes as flat together as possible and today i can see that there is a slight gap in between the flanges on the bottom. I can hear the exhaust leaking out and want to know if anyone else has this problem and what can be done about it.
Old Jan 27, 2007 | 10:52 PM
rally's Avatar
Only thing I could think of is take it to an exhaust shop and have them reweld the flange.
Nice illustration by the way
Old Jan 27, 2007 | 11:08 PM
RaineMan's Avatar
Good advice... just take it to an exhaust shop... they'll fix ya right up.
Old Jan 27, 2007 | 11:37 PM
hatrickstu's Avatar
yeah that is def. a good way to do it, i need to have them put the resonator back on as well...
Old Jan 27, 2007 | 11:42 PM
RaineMan's Avatar
sounds like you'll kill two birds with one stone.
Old Jan 27, 2007 | 11:46 PM
hatrickstu's Avatar
yeah but i just hope they dont charge me too much, they should not considering i had my catback system made there.
Old Jan 28, 2007 | 12:04 AM
RaineMan's Avatar
to fix that? probably an hours work max...
Old Jan 28, 2007 | 01:23 AM
hatrickstu's Avatar
**** 10 minutes max. they do good work too.
anyone else even have this problem?
Last edited by hatrickstu; Jan 28, 2007 at 01:23 AM. Reason: Automerged Doublepost
Old Jan 28, 2007 | 06:08 PM
hatrickstu's Avatar
anyone...
Last edited by hatrickstu; Jan 28, 2007 at 06:08 PM. Reason: Automerged Doublepost
Old Jan 28, 2007 | 06:42 PM
bamfnss's Avatar
goto a muffler shop, or cut off the flanges yourself and put a clamp like this for your connection...
http://vertexnow.com/Verocious-Motor...-Exhaust-Clamp
Old Jan 28, 2007 | 07:50 PM
Blown 4-banger's Avatar
HA HA HA!!! Man you make the best exhaust diagrams!!! So realistic!
jk man
Old Jan 28, 2007 | 11:46 PM
squeak's Avatar
what sice 16 inch drag radials are you runnig and what brand?
Old Jan 29, 2007 | 12:57 AM
hatrickstu's Avatar
dude this has no bearing on the thread, pm me if you really want to know
