Need help asap
Old Jul 14, 2009 | 11:32 AM
OiangeSS's Avatar
Need help asap
im at work and i need to kno where the tensioner is and how u change the serp belt on a 06 lsj plz i need help someone
Old Jul 14, 2009 | 11:37 AM
LamboW9's Avatar
next to the supercharger is the pulley, if you look directly behind that you will see another pulley with the belt on it, next to the pulley there is a small square notch if you put a wrench on that (15mm i think) and push down and away from you it will release the tension but you have to hold it down
Old Jul 14, 2009 | 11:45 AM
SCcobaltSS's Avatar
Old Jul 14, 2009 | 11:53 AM
LamboW9's Avatar
SCcobaltSS posted a good picture, he's pointing to the little square notch i mentioned, Good picture
Old Jul 14, 2009 | 11:57 AM
SCcobaltSS's Avatar
^Thanks, OP hope this helps finding it..
Old Jul 14, 2009 | 12:00 PM
northvibe's Avatar
oh man getting that tensioner back sucks as the wrench usually slips off that square chunk... Theres a custom part made by someone though that really helps...ugh forgot the name.
Old Jul 14, 2009 | 12:01 PM
red06SC's Avatar
get a wrench with a coated handle or wrap one in cloth, find that little notch on the tensioner and put a wrench in there, turn it so it is 90 degrees from the pulley and resting on it and the belt, use the black bracket to SLOWLY put pressure down on the pulley and shock, release the belt from the SC while holding tension off
Old Jul 14, 2009 | 12:05 PM
LamboW9's Avatar
mine slipped off on me a few times, if that is the case, go to a slightly bigger wrench and tap it on with a hammer, it won't slip off until you wiggle it off then, and yes you should coat the wrench with a cloth or something because they are quite stiff
Old Jul 14, 2009 | 12:08 PM
red06SC's Avatar
I don't see why you guys are rocking back with a 15mm wrench, if you're careful you can use the leverage between that black bracket and the top of the pulley to push it down very easily without damage.
Old Jul 14, 2009 | 12:16 PM
06cobalt racer's Avatar
i think he meant smaller. i was a 14 mm and tap it on. works great.
Old Jul 14, 2009 | 12:35 PM
OiangeSS's Avatar
thanks guys big help i think someone in here should make a "how to" for the LSJ and LNF
thanks again
Old Jul 14, 2009 | 12:39 PM
northvibe's Avatar
ugh I was helping with RallyRacers stage 2 install and it was a bitch, the wrench kept coming off. We had to pound one on. If we did it again that square is fucked...
This is the tool Im talking about that makes it 2209348349 times easier
http://pulleyboys.com/cobalt-ion.html#belttool
Old Jul 14, 2009 | 01:15 PM
rnjmur's Avatar
I have a prybar that works the best out of any other option I have tried.
http://www.sears.com/shc/s/p_10153_12605_00943278000P works just as good and doesn't cost $75 plus shipping.
Old Jul 14, 2009 | 01:16 PM
Rodimus_Prime's Avatar
i strongly reccomend getting the pulley boys tensioner tool, much much more awesome than using a wrench or pry bar
Old Jul 14, 2009 | 03:15 PM
LamboW9's Avatar
thanks again
i hate to be an ass, but there are tons of them on here, just some are harder to understand than others, and pictures are somtimes vague, hope all the information helps ya out
Cobe
Sep 19, 2015 11:04 AM
06noscobaltss
May 25, 2006 01:55 PM
Saki XL
May 16, 2006 01:34 AM
9JordonFlex9
Mar 26, 2006 08:05 PM
Cobalt30
Mar 11, 2006 02:50 AM
