Need help with new mods.
Old Jan 17, 2007 | 09:13 PM
Floridas Finest SS's Avatar
With a good custom tune and a 2.5" pulley, 60lb injectors, intake, and full exhaust but NO cooling, will I be fine?
Or will i be in danger of blowing up the engine?
Who all has these mods and a custom tune and how does the car run?
Old Jan 17, 2007 | 09:26 PM
DTM2188's Avatar
A 2.5" pulley is going to create some serious heat, I would say that you would definalty benefit from cooling mods and it would be much safer. So all in all, I would say go with some cooling mods as well.
Old Jan 17, 2007 | 10:10 PM
2K5SS/SC?'s Avatar
I would run a 2.6" pulley with that setup. It'll keep things cooler until you do the dual pass mod and a front mount HE.
Old Jan 17, 2007 | 10:43 PM
Thanks alot guys.
So would the Dual pass end plate give me the cooling that i need to not have my car run so hot?
Last edited by Floridas Finest SS; Jan 17, 2007 at 10:43 PM. Reason: Automerged Doublepost
Old Jan 17, 2007 | 10:50 PM
DTM2188's Avatar
The dual pass will definatly help you out a good bit. Throw in a Cobra H/E and you should be set up very nicely.
Old Jan 17, 2007 | 10:58 PM
quickspec's Avatar
Quick question, could you do a CA h/c and a dual pass plate or do they cancel each other out?
Old Jan 17, 2007 | 11:13 PM
You can do both, would actually be the more desirable option, but would the CA heat-exchanger be enough by itself? for the mods i'm looking to do?
Whats the negatives of running hot? besides being robber of hp?
Old Jan 17, 2007 | 11:49 PM
ReMz's Avatar
BOOM!!!
Old Jan 18, 2007 | 08:02 AM
DTM2188's Avatar
Aside from ^^^^ BOOM and loss of performance, it is also more strain on the engine.
Old Jan 18, 2007 | 10:37 AM
2K5SS/SC?'s Avatar
Do the dual pass mod first if you are strapped for cash. Then upgrade the HE for a killer combo.
Old Jan 18, 2007 | 02:05 PM
Which one does more for cooling?
Because with all aditional hardware and surge tank on the end plate they end up being the same price.
Also how much more heat does the 2.5" create over the 2.6"
Last edited by Floridas Finest SS; Jan 18, 2007 at 02:05 PM. Reason: Automerged Doublepost
Old Jan 18, 2007 | 02:56 PM
2K5SS/SC?'s Avatar
I believe the 2.6" pulley just barely goes over the superchargers redline. The 2.5" screams over the redline creating more heat and not hardly anymore power when tuned correctly.
Old Jan 18, 2007 | 03:23 PM
ReMz's Avatar
you would be much safer/reliable with a 2.6".... i dont think you will see much more power and the blower will be at it's absolute limits.
Old Jan 18, 2007 | 06:50 PM
DTM2188's Avatar
I agree, the 2.6" will be more safer/reliable and better off in the long run. If you do the dual pass and the H/E, then you'll be set.
Adecker
Sep 28, 2015 10:57 AM
brett.higgins3
Sep 24, 2015 09:51 AM
dieGone
Sep 23, 2015 10:20 AM
sweettheshocker
Oct 21, 2005 10:59 AM
JonyyB
Site Development and Help
Oct 20, 2005 10:07 PM
