need help now!!
need help now!!
just finished installing the 10:1 pistons and first of all i had to go get them pressed on to fit the rod. but now that there installed they sit to high and are hitting the valves. the install went fine. i dont know where i went wrong but they are hitting. any help please.
yeah and everything is installed right. either there the wrong pistons in the right box. i checked everything and they were the right pistons. so i have no idea. i will be calling diamond mon to try to get answers. i cant even turn the motor over by hand they are hitting the vavles. so i have no idea.
Crazy question but......are you sure the cams didn't get switched around? IIRC the pistons sat a little higher than the block. I think it's called quench style....but mine never hit the valves.
If I was to take 2 guesses right now......I'd say either Pistons are facing the wrong way or the came got switched around.
You can see the little "F" here....make sure it is facing the front (timing chain) of engine
I stole this pic from SSweet06
Last edited by M88ArRamadi; Sep 16, 2007 at 02:40 AM. Reason: Automerged Doublepost
