Need help on wiring meth activation LED
Old Apr 2, 2013 | 12:57 PM
volsfan92's Avatar
How do you hook up an LED that will let me know my meth pump is working?? Cant find anything on how to do it
Old Apr 2, 2013 | 01:17 PM
07ssBOOST's Avatar
Id imagine you just splice into the power wire at the pump and when its on youll see
Old Apr 2, 2013 | 01:45 PM
what kit are you on now?
Old Apr 2, 2013 | 02:47 PM
Bluelightning's Avatar
Got Bewst?
That will let you know if you are getting power to the pump but not tell you if the pump is working. Invest in a pressure switch and tap it in. Then you know for sure the pump is working.
Old Apr 2, 2013 | 09:26 PM
07ssBOOST's Avatar
I mean if you have a wideband you'll be able to tell real quick or if yiu have an interceptor you'll be able to tell by iat or just power loss....lota of ways
Old Apr 2, 2013 | 09:53 PM
Got Bewst?
You say that till it happens to you. Happened to me. Luckily I didn't pop my motor. Now I have that red light in front of my face with a pressure switch.
When you're focused on driving like at the track dummy lights are nice to have for certain things lol.
Old Apr 2, 2013 | 11:15 PM
volsfan92's Avatar
@Riceburner just a DevilsOwn stage 1 finally got back on my feet so I could afford one lol @Lightning My system is off a pressure switch is that what you mean??
Old Apr 3, 2013 | 08:49 AM
07ssBOOST's Avatar
I dont take mine to track lol so risk isnt as high
Old Apr 3, 2013 | 11:29 AM
Got Bewst?
I have the same kit as you. I mean adding the same style of pressure switch that activates your meth off boost, to get one that you can tap in line after the pump so when your pump starts up it lights up the led light as opposed to just tapping into the power source of the pump.
Old Apr 6, 2013 | 06:39 AM
MyOtherSS's Avatar
Did you just t into the meth line and send it to a 2nd switch?
Old Apr 6, 2013 | 11:31 AM
Got Bewst?
I just put the pressure switch Tee'd in the meth line and made a power connection through it. So when the meth kicks on, it activates the switch and puts power to the led
Old Apr 6, 2013 | 12:13 PM
microgab's Avatar
Damn thats really smart! I'll have my kit installed today, so I'll look into getting a pressure switch and all. I also have devils own stage 1. Hopefully they sell a kit with the T, switch, wiring and led for cheap
Old Apr 6, 2013 | 12:19 PM
Got Bewst?
Ya well after my meth pump seized solid on me I changed from tapping into just the power wire for the pump to installing a pressure switch. I'm not sure if Devilsown sells them but you shouldn't have problems finding one. It looks like the boost switch the kit comes with but has fittings on it for the meth lines to clip into.
Old Apr 12, 2013 | 08:38 PM
MyOtherSS's Avatar
Cool that's what I figured, what psi switch did you use?
Jan 12, 2016 12:01 AM
dennis69
Oct 20, 2015 07:39 AM
yellow dragon
Sep 28, 2015 09:49 PM
goaliemo
Sep 28, 2015 01:37 PM
Sep 27, 2015 08:53 PM
