Need a lil help plz
Old Aug 15, 2009 | 09:55 PM
07touringcoupe's Avatar
Need a lil help plz
Ok so today i was jacking my car up and the jacked slipped and the jack like kinda hit the radiator and its has a lil crack at the bottom so it leaks now, its not a big crack at all ots a VERY lil crack that cant even be seen wit the eye you can only see where it leaks. Till i can get a radiator is there somthin i can use to fill it or cover it or somthin to stop the leak?
Old Aug 15, 2009 | 10:07 PM
qwikredline's Avatar
Bars leak. autozone or napa etc
Old Aug 15, 2009 | 11:02 PM
thats the name of it?
I need a radiator. Will any cobalt radiator fit on the ss/sc
Last edited by 07touringcoupe; Aug 15, 2009 at 11:02 PM. Reason: Automerged Doublepost
Old Aug 15, 2009 | 11:04 PM
Zach06CobaltSC's Avatar
I don't see why you need a new radiator for such a small hole. Duck tape solves everything.
Old Aug 15, 2009 | 11:08 PM
You think duck tape would work? I mean that would only slow the leak down not stop it
Old Aug 15, 2009 | 11:16 PM
Bika's Avatar
Fail Less.
You have no business jacking up the vehicle by the lower core support. Don't do that. Use the recommended jack points...
Old Aug 15, 2009 | 11:18 PM
If it's as small as you are thinking it is and it's only leaking from one spot there are a lot of different options you could do to fix it. There really is NO reason to replace it for one small tiny little hole on the bottom of the radiator. You could use like a jb weld type of stuff, you could weld over it, you could do a lot of things really.
PS: Bika I think your tractor is sexy =P.
Last edited by Zach06CobaltSC; Aug 15, 2009 at 11:18 PM. Reason: Automerged Doublepost
Old Aug 15, 2009 | 11:19 PM
Maven's Avatar
StopsLeak, BarsLeak, any of the myriad of crap you can put in your radiator may help for a while (or may work forever) but you need a new radiator.
I doubt he was actually using the core support since they are merely two thin metal tabs, I thought it was obvious he was using the subframe which plenty strong.
Old Aug 15, 2009 | 11:20 PM
GreyDog72's Avatar
get it welded up. take it off and weld it shut. if u poor liquid seal **** u might stop up your radiator all togerther
Old Aug 15, 2009 | 11:44 PM
rad side suppiorts are plastic. needs anew oneor a goodone. bars leak will tide himover until he can buy one...
Old Aug 16, 2009 | 12:00 AM
nicksredline's Avatar
lol the liquid seal **** is made for radiators... so i dought it would clog it up. and i would say jb weld... except u have to let it setup for 15 hours!! i dident say minutes HOURS lol. i beleave its like 15-20 or so.... but definatly works wonders... also make sure u scuff up the surface and wipe all the antifreze off with brake cleaner or laquerthinner... something that will take the oilage off of it so it will actuily stick. it works wonders when done correctly.. and i think advace its like 5 bucks tax included so very easy and cheap.
Old Aug 16, 2009 | 12:05 AM
Maven's Avatar
JB QWIK. sets in like 5 minutes BUT......he needs a new one.
Old Aug 16, 2009 | 12:12 AM
Karlen89's Avatar
Take a picture, post the picture. Everyone then sits around, talks about it, and says the same thing. Then you buy a new one. Learn the lesson to only jack up the car from correct points, life goes on.
Old Aug 16, 2009 | 12:15 AM
Bika's Avatar
Fail Less.
uhh, thanks i guess. (no homo)
I wasnt referring to the radiator supports... but I still dont think that part of the front subframe behind the radiator would support teh weight of the car too well. Its only held on by like 2 bolts on each side. I figured that is more of an impact beam / structural brace. Idk. I still wouldnt use it, if for no other reason than the problem the OP encountered, and the fact GM didnt list it as a lift point.
PS. get the radiator welded by a professional, or replace it. Products like Stop Leak aren't guaranteed to hold forever, and you dont want the problem to rear its ugly head again at an inconvenient time.
[/2 cents]
Old Aug 16, 2009 | 12:17 AM
boostedss26's Avatar
Buy a new radiator, that bars leak **** will eventually end up plugging up your heater core and causing issues down the road.
Old Aug 16, 2009 | 12:22 AM
Maven's Avatar
[/2 cents]
The subframe is plenty strong.....its what actually makes the car stop, steer, bouce, and turn. Think about it. I use it to lift on occassion, but I know it isnt going to jump out of my jack cradle.
Old Aug 16, 2009 | 09:09 AM
yea i used the sub frame. I didnt know it was going to slide offeither but yea thats my dumbness i guess. Where are the jacking points? The side of the car? if so those are bend to ****. I dont know why they bend on these cars. Also does a reg cobalt radaitor fit on the ss? If so ima go to the junk yard and pull one off
i tried some of that epoxy stuff last night but i guess i did it wrong. First i forgot to clean the surface then. I guess i didnt let it set long enough. It slow the leak down but it still leaked
Last edited by 07touringcoupe; Aug 16, 2009 at 09:09 AM. Reason: Automerged Doublepost
Old Aug 18, 2009 | 07:16 PM
so where can i buy a radiator
Geo_SS
Sep 5, 2015 12:17 PM
717ssbalt
Sep 1, 2015 10:51 AM
mr.ss
Nov 19, 2005 05:04 PM
Co'Baller
Sep 14, 2005 01:26 AM
LSJ_Kid04
Aug 21, 2005 12:07 AM
