Need some answers before Wed. LSJ Valve Covers
Old Oct 10, 2010 | 04:36 PM
06G85's Avatar
What's involved with taking off an LSJ valve cover (I am going to paint one) Is it as simple as unbolt, paint, bolt back on? Or is there a gasket that needs to be replaced/special torque requirements. I need to know this
Thanks everyone!
EDIT 10/13 - Well, I finally got it off and painted. There was a few bolts than just the ones on the valve cover, but nothing we couldn't do.
Come to find out, the prior owner had stripped the inside of the coilpack covers bolts, and we got 2 of them out, the other 2 were a pain! I tapped one with the T-30 bit, and was able to get that out, the other was impossible. I had to bend his coil pack cover and turn it so the bolt would lossen up, tap some more, and kept going at it. Took almost and HOUR to get it out. Needless to say, it's painted and back together. Here are his pictures!
Old Oct 10, 2010 | 04:39 PM
05Slowline's Avatar
just unbolt lol
shouldn't need a gasket unless you gank it up
Old Oct 10, 2010 | 04:40 PM
09xfebalt's Avatar
Originally Posted by 05Slowline
just unbolt lol
and rebolt haha
Old Oct 10, 2010 | 04:41 PM
05Slowline's Avatar
yea that helps too lol
Old Oct 10, 2010 | 04:52 PM
06G85's Avatar
Any torque specs?
Old Oct 10, 2010 | 06:39 PM
advise's Avatar
believe its 89in lbs but not 100% necessary
Old Oct 10, 2010 | 06:42 PM
troyss's Avatar
I was wondering the same thing and what is the best paint to use if anyone knows?
Old Oct 10, 2010 | 06:52 PM
Cefaln452's Avatar
make them tight
Old Oct 10, 2010 | 07:04 PM
Ting-ting's Avatar
*** no not 89 pounds you will crack it just 1 nut sack hand tight
you can use krylon i have before it just doesnt clean as well as high temp engine paint
but all most any spray paint will work just dont expect it to clean amazing
Old Oct 10, 2010 | 07:17 PM
Ting-ting's Avatar
here the one on my balt the paint is metalspeckle got it from autozone
and my rsx valve cover metal x paint
Old Oct 10, 2010 | 07:23 PM
RooTBeeR's Avatar
10ft/lb iirc
Old Oct 10, 2010 | 07:25 PM
Ting-ting's Avatar
that sounds better lol
Old Oct 10, 2010 | 07:27 PM
HyperMuffin's Avatar
89in/lbs is actually less tight than 10ft/lbs
89in/lbs = 7.41 ft/lbs
Old Oct 10, 2010 | 07:32 PM
Ting-ting's Avatar
o snap i missed the "in"
Old Oct 10, 2010 | 07:41 PM
09xfebalt's Avatar
Tighten
Tighten the camshaft cover bolts to 8 Nˇm (71 lb in).
directly from Service information
Old Oct 10, 2010 | 07:47 PM
RooTBeeR's Avatar
troof
lol yes i saw you did that
Old Oct 10, 2010 | 08:34 PM
troyss's Avatar
Is clear coat needed?
Old Oct 10, 2010 | 09:36 PM
06G85's Avatar
So, I will need a new gasket too then if I take it off to paint it? RIght?
Old Oct 10, 2010 | 09:54 PM
RooTBeeR's Avatar
no, i pulled off my valve cover to install my header and put it back on, tq'd the bolts and no leaks or anything since
Old Oct 10, 2010 | 09:55 PM
06G85's Avatar
Ok thanks. Where could I get one quickly if I needed one? Or do I have to order it...
I maybe doing it in a parking lot that has an Advanced Auto in it.
Old Oct 11, 2010 | 08:13 AM
SunburstSS's Avatar
i did that like 2 month ago, mine was leaking to begin with so i went ahead and used some high heat silicone around the gasket after i painted my valve cover, but if ur careful with the gasket u'll be fine...
Old Oct 11, 2010 | 09:13 AM
Lifter's Avatar
I'd probably do this any ways, just to be safe.
Old Oct 11, 2010 | 09:52 PM
06G85's Avatar
Will do! Thanks guys!
Old Oct 13, 2010 | 09:54 PM
06G85's Avatar
Bump for pics in first post!
Old Oct 13, 2010 | 10:45 PM
Frew's Avatar
dude im in love with the center section that covers the coils, what is that? a vinyl?
