Need some help please.
Old Jun 4, 2008 | 11:04 AM
wildkyle90's Avatar
ok so im planning on getting stage 1 from gm and having them put it on. but after that im planning on getting a smaller pully. i already have a cold air intake so what size pully would you reccomend for daily driving? thanks.
Old Jun 4, 2008 | 11:06 AM
DoubleLP's Avatar
You should just go with the Stage 2. That way you get everything from GM and it is all under warranty. And the Stage 2 pulley is smaller then the stock pulley size. It will make the car a completely different beast.....but still a great daily driver.
Old Jun 4, 2008 | 11:07 AM
invisible's Avatar
Don't waist you're time with stg 1. Get stg 2 and run a 2.9
Old Jun 4, 2008 | 11:10 AM
wildkyle90's Avatar
so does the stage 2 come with the 2.9 sized pully?
Old Jun 4, 2008 | 11:12 AM
light'bolt's Avatar
don't forget the belt too
Old Jun 4, 2008 | 11:13 AM
Drakonen2000's Avatar
nope...but you can get one perdy cheap that will bolt right up to the stgII hub!!!
DoubleLP's Avatar
Nope........3.1
You can get the 2.9 from Smoothflow Pulleys. They are a great vendor on here.
Old Jun 4, 2008 | 11:15 AM
SmOKe JeNsOn's Avatar
I did the exact same thing only bad thing is trying to find a puller to get the factory pulley off
Old Jun 4, 2008 | 11:31 AM
wildkyle90's Avatar
thanks guys. but where am i gonna get the tool to get the pully tool at to get it off?
Old Jun 4, 2008 | 11:38 AM
brett5's Avatar
autozone
pep boys anywhere you should just do everything yourself and take it to the dealer for a re flash its so easy and saves you money
lewisb13's Avatar
From: Home: Utica, MI Current Location: Mobile, Alabama
Just get stage 2, you need the tune anyways.
Old Jun 4, 2008 | 11:41 AM
the tune is the same as stage 1
Old Jun 4, 2008 | 11:47 AM
brett5's Avatar
Agreed
it might be cheaper to buy the stage one then just buy a 2.9 somewhere cheaper then buy the belt and hub from gm for like 50 bucks.nate makes them on ebay pretty cheap
Old Jun 4, 2008 | 11:49 AM
lewisb13's Avatar
I know this, Im just saying its a bitch to get the stock pulley off, plus you have to change the belt. You are better off getting stage 2 so they know you have the smaller pulley installed. Then you can but one of those 2.9s that looks exactly like the stage 2 pulley and has GM or whatever stamped on it.
Old Jun 4, 2008 | 11:52 AM
Yea true I did it this way just because I work at a chevy dealer so it was about $150 cheaper going the stage 1 with a 2.9
Old Jun 4, 2008 | 11:58 AM
brett5's Avatar
its actually pretty easy to get the stock puller off with a pulley puller and have someon sit on the blower
Old Jun 4, 2008 | 05:09 PM
wildkyle90's Avatar
so how much whp difference will i see betweet the 2.9 pully and the stage 2? by the way arnt are cars underrated anyway putting out more at the wheels than the 205hp stated?
Old Jun 4, 2008 | 05:15 PM
PinaSS's Avatar
just go with s2
Old Jun 4, 2008 | 06:36 PM
wildkyle90's Avatar
yeah. wheres the cheapest place to get the stageII?
Old Jun 4, 2008 | 07:25 PM
brett5's Avatar
crateenginedepot.com
speedlimit
Site Development and Help
Sep 25, 2015 08:04 AM
turbaltss08
Sep 14, 2015 10:19 PM
azreal
Nov 10, 2006 10:13 AM
RedBaseBolt
Jul 23, 2006 12:41 PM
