Need some info before i buy Intense kit
Old Mar 23, 2006 | 12:22 PM
BlkDragon SS's Avatar
Hey guys ok I have more or less decided to go and get the intense kit for my SC.
But there are a few things i need to know about it.
First: if I do get it, is it imperative to do the boost bypass mod ( kinda don't wanna F with that)
Second: Which plugs are best and what is best gap for this kit?
Third: Has anyone ahd any prblems with this kit other than the occasional KR which is minnimum at best?
Thanks to all who respond if you wanna leave me an email with more detailed info on this kit about its pro's and cons please do. My email is the_big_kruh@hotmail.com. Thx again all
Old Mar 23, 2006 | 01:26 PM
djt81185's Avatar
yes its required
autolites intense sells gapped .045
If you have an 04 redline there is problems. Also some issues with throttle surging and hiccups. Very minor though.
Old Mar 23, 2006 | 01:27 PM
GSoccer24's Avatar
umm i don't think it's really required to do the boost bypass mod...anyone else have an answer on that?
Old Mar 23, 2006 | 01:33 PM
maxpit's Avatar
Someone please explain the boost bypass mod and its exact purpose. I looked at the other post but "no comprende".
Old Mar 23, 2006 | 02:24 PM
djt81185's Avatar
If you dont do the boost bypass how are you going to take advantages of all the air coming in witht he new pulley. Trust me its required. I have the kit on my car
Old Mar 23, 2006 | 02:27 PM
djt81185's Avatar
OK look at you s/c. See the big black thing on top that kinda looks like a fat flying saucer. That is the bypass valve actuator. Look at it there are 2 hoses going to it. Grab the bottom hose (if you follow it back it leads to a solenoid) and remove it from the actuator. you can plug this or leave it open. I personally installed a manual boost controller inline between the 2 and closed it off do the boost can be vented and I can turn it down if needed.
Old Mar 23, 2006 | 02:28 PM
R33P3R007's Avatar
360 L337 User
Edited... HIS was Better ^^^^
Old Mar 23, 2006 | 02:29 PM
R33P3R007's Avatar
360 L337 User
do you have a pic of that?
Old Mar 23, 2006 | 02:35 PM
GSoccer24's Avatar
right but it's not like the kit won't work at all. i just don't know how i feel about the bypass mod in relation to the life of some of the related components and their intended/designed usage.
Old Mar 23, 2006 | 02:38 PM
djt81185's Avatar
Well with the intense kit you are adding additional fuel. If you add fuel but dont add air your just going to bog out. You need that extra air. GTP owners have been overspinning these things for years with no problems.
Old Mar 23, 2006 | 02:39 PM
djt81185's Avatar
I'll try to grab one today. be forewarned itll probably be a crappy camer phone pic but youll get the picture
Old Mar 23, 2006 | 02:43 PM
max_boost's Avatar
If you are to worried about the life of parts and do not want to do the bypass mod I think the intense kit is not for you. The only reason the boost bypass is there to begin with is becuase the stock injectors can't handle boost levels above 12-12.5. In order to keep the car from leaning out with stock injectors the car dumps the boost. With the intense kit you will not have a shortage of fuel and can disable the bypass.
I think the car will actually run worse without the bypass mod done because the computer will dump your extra boost causing it to run really rich in the upper rpms.
Old Mar 23, 2006 | 03:41 PM
GSoccer24's Avatar
gotcha, see now that makes sense. all the other stuff i've been reading hasn't described it quite that clearly for me, but that was great, i thank you.
so what is the advantage/disadvantage of doing the bypass on a stock setup?
Old Mar 23, 2006 | 03:43 PM
max_boost's Avatar
You're welcome. There is no advantage to doing it on a car with the stock pulley.
Old Mar 23, 2006 | 05:49 PM
ENUFPWR's Avatar
Yes the bypass mod has to be done with the kit otherwise you run rich and boost is limited to stock levels like others have mentioned.
Old Mar 23, 2006 | 11:20 PM
Crunchy's Avatar
ok. question. If I get just a 3" pulley and 1 step colder plugs, then I do the boost bypass, do I need to get injectors, or will it lean out at all. ZZP said that with a 3" you dont need new injectors, but I dont think they included a bypass mod to it either...help...
Old Mar 24, 2006 | 01:41 AM
Sinisterredlines's Avatar
Been running the 3" pulley and bypass for awhile and no probs. Threre a buch of us RL's that have it setup and it works great but I'm on to bigger and better mods lol
Old Mar 24, 2006 | 07:18 AM
Rogue's Avatar
You can run a 3" with stock injectors but you still need to do they bypass to take full advantage of the extra boost the smaller pulley can make. All the bypass consists of is blocking of a hose to the boost bypass controller.
ineedacobaltss
Nov 7, 2015 02:25 PM
OrangeCoba
Oct 1, 2015 10:00 PM
dieGone
Oct 1, 2015 06:27 PM
yellow dragon
Sep 28, 2015 09:49 PM
Sep 28, 2015 12:51 PM
