In need of this wire
Old Feb 10, 2008 | 12:49 PM
Coblt ss super's Avatar
anyone know where i can get the wire that connects into the rear O2 sensor? the one that connects at the rear tranny mount and goes up to god knows where. I kinda pulled the wires outta it and broke the harness. My CEL keeps coming on because its not hooked up right anymore so i wanna get a new one so it doesnt keep throwing a CEL.
Old Feb 10, 2008 | 12:53 PM
tsunam1's Avatar
That sucks, if you have the plug you can pull the pins out and solder on new lead wires, then reinsert them into the plug then solder the leads to the wires on the car. Just make sure you don't cross the streams lol....
Old Feb 10, 2008 | 12:56 PM
i still have the metal prongs on the wires from the top, i just dont know which way they go back in?
Old Feb 10, 2008 | 01:13 PM
tsunam1's Avatar
if it is just 2 wires then I don't think it matters, how hard is it to get to the rear o2 sensor without lifting the car? Maybe I can snap a photo of mine for reference?
Old Feb 10, 2008 | 01:14 PM
its on top of the rear tranny mount, but its 4 wires, let me know they are like pink green and some other colors
Old Feb 10, 2008 | 01:19 PM
tsunam1's Avatar
I'll go take a look....
Old Feb 10, 2008 | 01:20 PM
ok thanks
Old Feb 10, 2008 | 01:41 PM
tsunam1's Avatar
No pink wire, I have black, grey, and two whites. They are labeled A= Gray, B= Black, C & D = White. It is mounted right on top of the transmission/rear motor mount. When the camera charges up I'll snap a photo.
Old Feb 10, 2008 | 01:42 PM
what year is your car and is it an ss s/c?
and im talking about the wires that go from the connector to the pcm i think, not the wire that connects to the harness and goes to the O2 sensor
Last edited by Coblt ss super; Feb 10, 2008 at 01:42 PM. Reason: Automerged Doublepost
Old Feb 10, 2008 | 01:46 PM
shaunmcdee's Avatar
You talking about the signal wire that runs back into your pcm?
Old Feb 10, 2008 | 01:47 PM
yeah that one, from the harness to the pcm
Old Feb 10, 2008 | 01:49 PM
shaunmcdee's Avatar
and what were u trying to do about it? connect it back to the pcm side or the harness that attaches to the rear o2 side?
Old Feb 10, 2008 | 01:51 PM
i was changing my tranny mount inserts, i pulled the rear tranny mount down and pulled the metal prongs outta the harness for the wire, now i need to know where i can get a new wire or how the wires go back into the harness. the O2 wire is fine, the wire it connects into is the one that got messed up
Old Feb 10, 2008 | 01:55 PM
tsunam1's Avatar
I pulled it off of the mount so I could look at it but thats it, mine is a 06 2.4 but you think that the o2 sensors would be the same
Old Feb 10, 2008 | 02:00 PM
shaunmcdee's Avatar
you cant see which prong has the empty wire?....or knowing our cars, it has multiple slots where it can go, lol. Damn dude, the only thing i would try doing is physically getting back under there, and look at your harness connectors and see if you cant see anything. Asides from that i dont think there much u can do minus shutting the code off via hptuners, or waiting for someone more knowledgable to throw up a wiring diagram. Sorry i couldnt be more help.
I think he talking on the opposite end of that harness.
it goes o2 sensor > o2 harness then from o2harness > pcm harness
he needs to see where the 02 harness to pcm harness goes.
Last edited by shaunmcdee; Feb 10, 2008 at 02:00 PM. Reason: Automerged Doublepost
Old Feb 10, 2008 | 02:08 PM
ok so the pic shows one side whats the other side look like thats the side im talking about
Old Feb 10, 2008 | 02:10 PM
06REDSS/SC's Avatar
you cant get a new wire, that connector is attached to the complete engine wiring harness.
i have some pics that i will post in a minute
Old Feb 10, 2008 | 02:11 PM
ok thanks alot, how much does this wire cost? if not ill just put the prongs into the other harness so it works
Old Feb 10, 2008 | 02:13 PM
Super_SS's Avatar
u throwing the p1133 code?
Old Feb 10, 2008 | 02:14 PM
no im throwing
P0036
P0300
P0138
those codes
Old Feb 10, 2008 | 02:16 PM
Super_SS's Avatar
Originally Posted by Coblt ss super
no im throwing
P0036
P0300
P0138
those codes
danm,that yellow light inside the cluster must be annoying
Old Feb 10, 2008 | 02:19 PM
yeah but i turn it off everytime it comes on, sometimes it doesnt come on at all, but Interceptor FTW
Old Feb 10, 2008 | 02:23 PM
06REDSS/SC's Avatar
here you go, hope this helps you out
Old Feb 10, 2008 | 02:25 PM
ok yeah that helps, imma go check the wires tomorrow and see if i can get them in there and hold em in so they dont move
Old Feb 10, 2008 | 02:28 PM
06REDSS/SC's Avatar
if you wanted to replace that wire, you would have to replace the entire harness unless you could find a spare harness and splice the new connector onto your existing harness.
these pics are from a complete spare motor and tranny sitting in my garage.
