needdd answer asap????
Old Oct 21, 2008 | 07:58 PM
usdm08's Avatar
hey guys i have a 07 cobalt ss/sc n i had the gm stage 2 (injectors,stage tune,pulley) n i was gonna sell it to my friend which has a stock ss, can i just take off the injectors n my ecu n put it on his car n i put his stock injectors on mines n his computer?????? if not what do i have too do
Old Oct 21, 2008 | 07:59 PM
Herndon_High_SS's Avatar
double post ftw.
Old Oct 21, 2008 | 08:00 PM
R&C_rallySS's Avatar
I'm pretty sure if you switch your ECM, injectors, pulley, to his car, and put his ECM, injectors, and pulley on your car. You will be back to stock, and he will be stage II. The only problem I for see is the vin code. I know once your ECM is flashed its a stage II registered vin.
Old Oct 21, 2008 | 08:03 PM
BLAZIN07SS's Avatar
I'm too JDM for you
its more complicated than that. you will both need a crankcase relearn that only a dealer can do with a Tech2 scanner
Old Oct 21, 2008 | 11:48 PM
theneelster's Avatar
Um...what? I think you can...you can do it in the redline. Takes 20-30 minutes. You can just unplug the battery for 30 minutes and that will do it (as I had learned it).
But the deal is this...(edit) the vins need to be changed. He has a stock ss/sc I'd assume not a stock 2.4...
dennis69
Sep 23, 2015 02:56 PM
dieGone
Sep 23, 2015 10:20 AM
Cobe
Sep 19, 2015 11:04 AM
09BlkCrusader
Sep 9, 2015 04:47 PM
