new clutch but leaking fluid?
Old Apr 10, 2011 | 08:15 PM
dawgscj7's Avatar
05 ss/sc- I replaced the clutch and throw out bearing and that stupid little pipe- but it wont bleed and its leaking, so please give me an idea of whats wrong.
please add pics if you have them or direct me to the appropriate thread with pics because i think the actuator block isnt clicking down on to the new pipe and/or i dont know exactly what position the clip is supposed to be in for bleeding(PICS PLEASE).
Thats all i need and i can have my daily back ....please, please, please help. I live in cincy if your local just come show me so i can put it back on the ground.
Old Apr 11, 2011 | 10:39 PM
dawgscj7's Avatar
Bled clutch and tightened fitting to the throw out bearing did total reassembly today and started and brake fluid poured out of the bottom of the case what is the problem!!! Help!!!
Old Apr 11, 2011 | 10:44 PM
Chevycobaltss3's Avatar
T.b was bad... Its a known issue gm sold bad tb to alot of vendors so u mut have got one
Old Apr 12, 2011 | 07:25 AM
shroogis's Avatar
Did you get the GM Upgraded clutch kit with the NON green TOB? If so, I doubt the TOB is leaking.
Also, does your clutch hold pressure? I had a similar problem and my problem was 2 seals at the distribution block. Your clutch pipe had a new one on it and I bet the old one is still inside the distribution block. Remove the feed line, pull out the C clip and pop the distribution block off. Flip it over and see if the old seal is still inside. If so, use a pick and pull it out. It will take a few days for all of the fluid that leaked past the 2 seals into the bellhousing to finish draining out.
Old Apr 12, 2011 | 07:56 AM
sold alot of t.b for the lnf that were bad, so therfore this is the lnf t.b so it can leak.
Old Apr 12, 2011 | 10:14 AM
dawgscj7's Avatar
I have a green t.b......great
Old Apr 12, 2011 | 10:17 AM
Lmao. Sorry bro.
Old Apr 12, 2011 | 01:20 PM
shroogis's Avatar
I wouldn't pull it all apart yet. See if the clutch holds pressure and see if you had 2 of those little black seals under the distribution block...
Old Apr 12, 2011 | 06:34 PM
dawgscj7's Avatar
Distribution block is good just checked
Old Apr 12, 2011 | 08:47 PM
loco-performance's Avatar
Do you have any link or proof of this. I've replaced mine 3 times in 1 month last year. Want that money back for their own faulty products.
Old Apr 12, 2011 | 10:18 PM
Call crate engine depot and ask lol theres tons of threads on here bout it
Old Apr 12, 2011 | 10:20 PM
Thank you good sir.
Old Apr 12, 2011 | 10:25 PM
U r welcome bro i bought one from ced and it was bad. I installed it correctly and it just wouldnt expand correctly and all of a sudden i see fluid underneath my car wtf lol
Old Apr 13, 2011 | 10:51 AM
dawgscj7's Avatar
I purchased mine from ced too who did you buy your t b from that actually worked
Old Apr 13, 2011 | 11:26 AM
From gm at my dealership.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
biniecki
Oct 25, 2015 02:23 PM
brandon04
Oct 21, 2015 07:04 AM
SSLOW06
Oct 1, 2015 07:21 PM
