New IC Pump NEED HELP!
Old Mar 13, 2012 | 06:22 PM
reduf99's Avatar
sjc0013 Licks windows
I just got a new ic pump and installed it but my iat2 temps are still running over 100. I've checked all my tubes and everythings connected right . I'm stumped can anyone shed any light on the subject
Old Mar 13, 2012 | 06:28 PM
SylverSS/SC's Avatar
did you bleed the system of air pockets?
Old Mar 13, 2012 | 06:42 PM
BLue NoTe's Avatar
Brand new pump or a used one? And bleeding the system is key, option b rules
Old Mar 13, 2012 | 06:51 PM
reduf99's Avatar
After I put the pump on I filled the neck then turned the car on and added more coolant and more it jus kept cycling through so I took it for a ride like 5-10 min to see what the temps are and they were over 100 and right around 114 for cruising what else should I do?
Old Mar 13, 2012 | 06:53 PM
reduf99's Avatar
brand new pump
nikemax21's Avatar
its going to take alittle to bleed the system. Drive it around a little and check everytime u shut the car off. Add as needed. Im sure there r still some air pockets in the coolant system.
Old Mar 13, 2012 | 07:02 PM
reduf99's Avatar
Yea that's what I've been doing I'm hoping it gets straightened out
Old Mar 13, 2012 | 07:07 PM
BLue NoTe's Avatar
Can you get away with straight distilled water this time of year where you are? Might help a bit over antifreeze
Old Mar 13, 2012 | 07:16 PM
scoobydoobie's Avatar
Why do you think they should be under 100?
Old Mar 13, 2012 | 07:22 PM
reduf99's Avatar
I'm in pa and right now its 65 and I was told by nick at byt that I shouldn't be doing any pulls when its over 100
Old Mar 13, 2012 | 07:24 PM
microgab's Avatar
So whats the best way to bleed air? I changed my pump last week...just want to make sure I did everything right lol
Old Mar 13, 2012 | 07:41 PM
Interesting, I've never heard that. Without all the cooling mods I don't see how you could keep it below 100. Even then it wouldn't be easy.
Old Mar 13, 2012 | 07:56 PM
reduf99's Avatar
I have a zzp s3 h/e dual pass on a 2.9 " pulley
Old Mar 13, 2012 | 07:57 PM
Blowncavy's Avatar
100 is not bad temps really
Old Mar 13, 2012 | 08:00 PM
advise's Avatar
it should be around 15 to 25* over ambient temp.
Old Mar 13, 2012 | 08:07 PM
BLue NoTe's Avatar
It just has to run for a bit to circulate all the coolant. Gravity alone cant quite fill the entire system 100% even with either the option b or the stock crappy t neck filler being the highest points in the system. As the pump runs the level will appear to go down, just add more coolant as necessary
Old Mar 13, 2012 | 08:08 PM
reduf99's Avatar
My temps been between 102-118 and my intake temp sits around 75 ish
Old Mar 13, 2012 | 10:26 PM
Sweet CobaltSS's Avatar
is anyone upgrading to a higher flowing IC pump?
Old Mar 13, 2012 | 11:30 PM
reduf99's Avatar
I just did the replacement oem one from zzp
Old Mar 13, 2012 | 11:35 PM
BLue NoTe's Avatar
Nope
Tech info on the stock LSJ intercooler pump | | ZZP NewsZZP News
Old Mar 14, 2012 | 12:02 AM
nizzle's Avatar
Before I did all my cooling mods, my iats were around 120 in the winter and 140 in the summer (Seattle, WA). If you are at 100 with only a zzp S3, you are fine
Old Mar 14, 2012 | 12:06 AM
mrbelvedere's Avatar
your temps are fine if your iat2 gets overf 150 on a hard pull then you have a problem
Old Mar 14, 2012 | 02:09 AM
SunburstSS's Avatar
if ur cruising and letting off the gas the iat2 will go up since there's not a lot of air going in and cooling the s/c...Try crusing and keep on the gas and monitor ur iat2's if its not within 15-25 * apart from ur ambient temps, check ur intercooler pump's cables polarity, some cars were wired wrong from factory and the pump wont work properly. My IC pump wiring was revesed + going - and vice versa, I switched the up and problem was solved. You can use a voltage tester on the plug it self. Check those couple of things out and report back.
Old Mar 14, 2012 | 06:51 AM
reduf99's Avatar
Ok thanks for the help guys
Old Mar 14, 2012 | 07:07 AM
Hmmm. 6.25 GPM doesnt seem sufficient compared to the 21 GPM on my STS-V.
