New Pb.....but
Old Nov 19, 2006 | 07:50 PM
R33P3R007's Avatar
360 L337 User
New Pb.....but
I through 4 Codes, any Ideas what I need to do to fix them
1. P0103 Mass Air Flow (MAF) Sensor Circuit High Frequency -PCM
2. P0171 Fuel Trim System Lean -PCM
3. P0068 Throttle Body Airflow Performance -PCM
4. P1182 Supercharger Inlet Pressure Sensor Performance -PCM
Can anyone explain these to me in Lamens terms. And Help me out?
oh yeah. 13.23 is my new Personal best.
Old Nov 19, 2006 | 07:54 PM
R33P3R007's Avatar
360 L337 User
Oh yeah.. low coolent came on the Display and dinged at me, but i kept on the gas and ran the 13.23.
Old Nov 19, 2006 | 08:04 PM
zinner's Avatar
Moderator Alumni
What are your mods?
Old Nov 19, 2006 | 08:05 PM
p7x's Avatar
p7x
Originally Posted by zinner
What are your mods?
x2... nice run by the way
Old Nov 19, 2006 | 08:16 PM
97 Z Me Go's Avatar
the low coolant light probly came on from the harsh launch tosing the coolant around in the bottle thus seting the sensor off saying it was low/empty becaue the coolant being sloshed around i had the same thing happen to me at the track it was outa the hole.
Kyle
Old Nov 19, 2006 | 08:48 PM
Bad06SS's Avatar
I'm not sure on the codes, but great time! Post a timeslip with ALL mods, and i'll update it on the list!
Old Nov 19, 2006 | 11:59 PM
R33P3R007's Avatar
360 L337 User
What are your mods?
CTI Header
CTI Downpipe
GM Stage 2
2.7 Billetflow (This Day only) Normally 2.9
Hoosier QTP Drag Radials
R33P3R007's Avatar
360 L337 User
and i've gotton the p0171 lean every few months since i got the car. even stock.
Old Nov 20, 2006 | 12:58 AM
2K5SS/SC?'s Avatar
Nice runs. I bet the 2.7" with a GMPP Stage 2 tune is what threw all those codes. I would definately put the 2.9" back on. I see those QTP's helped the 60ft times a bit though.
Old Nov 20, 2006 | 06:59 AM
DWK5150's Avatar
Nice numbers so how do we like the hoosiers???
Old Nov 20, 2006 | 07:21 AM
zinner's Avatar
Moderator Alumni
Sounds like your MAF is a bit messed up.
P171 means your computer has to add more than 20% extra fuel in Closed loop mode at some point, which usually means your MAF is reading lower than it should.
However P0103 means your MAF was reading over it's limit which is probably 10k or 11k, I know a lot of people have to up this limit with mods.
The last two or rational checks meaning your MAF, MAP, TPS, SCIP sensors are lining up right (they should in essence back each other up and if they are too far off you will get that error)
Do you have an intake of some sort or amybe a K&N filter (oiled). You need to data log your car's MAF, MAP, SCIP, TPS, RPM, LTFT, ect to get a better idea.
It could be tuning or it could be a bad maf, or maybe any other one of those sensors thats throwing off the mix. I only think MAF because the 0103 is MAF related exclusively and the P0171 is also MAF related in closed loop mode.
Old Nov 20, 2006 | 08:50 AM
R33P3R007's Avatar
360 L337 User
other then the airbox mod no
Old Nov 20, 2006 | 09:07 AM
eastcoastz's Avatar
Nice run bro! To get rid of the P0103 and P0171 get the updated GM Stage kit reflash. The P0171 also can also be caused by simple **** like your dip stick not fully seated or and intake\vaccum leak after the MAF sensor.
Old Nov 20, 2006 | 03:06 PM
R33P3R007's Avatar
360 L337 User
ok, i still have yet to get the updated flash. i'll see if that works. so i need to go back to the dealer that did my install or can my local one do it.
Old Nov 20, 2006 | 06:30 PM
zinner's Avatar
Moderator Alumni
Well an AIRbox mod could cause a P171 code. It's been know to happen. Do you have the stock filter? Even the pleats being bunched on the stock filter can cause the code.
Old Nov 20, 2006 | 06:32 PM
R&C_rallySS's Avatar
I agree and congrats on the 1/4th time. I want to be there one day....
Old Nov 21, 2006 | 08:42 AM
R33P3R007's Avatar
360 L337 User
i've had it for 19,000 miles. ive had the 171 before, but never the rest
