new sleeves for the lsj and more
your block will be insanely strong without spending a fortune
ZZP Girdle using your own block:
$1000 girdle
$175 freight return (x2) to business addy
$100 Main bearings and seals
$1450 your block, USA shipping included
Add $500 for a LSJ core and subtract $175 for shipping to ZZP
$1775 ZZP core block, USA shipping included
TTY main bolts included, (20 X $3.25 and 10 X $5.25 =$117.50) those are CED prices btw
It will be interesting to see what the total cost of these sleeves installed is exactly,
Cost of sleeves
Install and hone deck and rebore machining
$117.50 TTY main bolts
$100 Main Bearings and seals
Shipping charges
My automotive machinist here, a 40 year guy charges $80 an hour and doesn't give deals but does A1 quality work, no corners cut. Someone already posted $125 per cylinder for press fit and rebore, that is $500 for machining alone.
Blue, if Mr.B is willing I'd ship him the upper portion of your block and have him do the work. When I trashed my block I cut it into scrap and total weight aluminum only including head was 119lbs, upper portion is 40lbs at most and can be boxed up pretty easy.
$1000 girdle
Cost of sleeves
Shipping charges
Way ahead of way haha. The downfall if I was to get a girdled block from ZZP is I wouldn't get any core charge for my block. It's f'd. I blew it up good. So add another $500 for no core.
Is there a way to get ahold of a set of these? I'm building a motor for a turbo swap next year and I want to resleeve the block and darton seems to be the only aftermarket replacement until now
I apologize, wasn't trying to start crap that's why I didn't name names. Just a general rule of thumb.
These sleeves sound very promising. If I ever need a build ill def be looking in this direction. Girdled block is great but seems overkill for most ppl.
