new sleeves for the lsj and more
Im sleeving a gen 3 2.0 buick turbo block with 090 wall hi performance custom made sleeves . At the shop now. The gen 3 2.0 comes with no sleeves and the cylinder walls are extra thick. They cant be bored because of the special treatment of the aluminum is only a couple thousanths thick. This block should be invincible. Heh Heh
do you mean piston rings? I bought new and re-sized them, they are only 100 bucks for the set. I have 180 compression across all cylinders and over 200 psi wet on a cold motor. Buy new rings and fit them for the new piston to wall clearance.
no actual cylinder head rings. I was messing around on CED's website and stumbled across this:
Ecotec Head Gasket and 0-Ring Kit 88958614
I've never heard nor seen these "o-rings" on our motors. I already have a cosmetic head gasket so I wasn't going to use it, I was just curious
yes you'd use it in a high boost or nitrous application. the downfall is they don't really seal the coolant as good as oem so it'll seep a bit. but for a drag only application it would be fine. most drag engines that are using an o ring block aren't running coolant anyways.
Im not a big fan of the stock gasket. Ive been into a few ecotec engine and always used a cometic never had a issue.
Spent alot of time talkin with bates and a few other ppl about it.
They all say cometic is the way to go. But everyone has there preference.
I am curious of doing this. I am guessing I would have to get custom sleeves like you did for your gen 3 2.0 block. There are a ton of these motors out there, and I am sure I could eventually scoop up a core from my work (I work at a buick, gmc, caddy dealer). I would want to keep the 2.0 bore size though.
If you don't mind, how much did your custom sleeves run installed?
Sorry for the derail mrB. I talked to you about these sleeves a long time ago on gmsc and found this thread.
