The Nitrous Question
Old Nov 4, 2008 | 09:21 PM
kevsmu4's Avatar
Did a quick search found a couple threads pertaining to my question's.
For the cobalt ss s/c guy's running nitrous or anyone knowledgeable in regards to nitrous:
2007 Cobalt SS S/C
I am looking to run a 35 shot
Mods= CAI
Dry or Wet?
Recommended kit?
Looking for something reasonable in price....
If you are not a fan of nitrous don't reply to this thread, I'm not looking to get bashed.
If you really feel it necessary to bash me, yes I am trying to blow up my engine
Old Nov 4, 2008 | 09:26 PM
SSdan's Avatar
Dynotune wet kit.
Old Nov 4, 2008 | 09:29 PM
ItalianJoe1's Avatar
Go wet, its much easier and works better when you want to up the shot.
50 shot or smaller and you will be fine.
Honestly, all kits are pretty much the same, cheaper kits bring cheaper components, but it all works. More money spent up front brings longer lasting parts. I prefer Holley/NOS brand kits, as they use stainless steel hardware instead of chromed brass, and thier solenoids are a little better than average. Sniper kits are Holley's 'budget' kit, with cheaper parts, but all thier other stuff is really nice.
Old Nov 4, 2008 | 09:30 PM
BLAZIN07SS's Avatar
I'm too JDM for you
wet shot.
what about my monster NX solenoids? haha
Old Nov 4, 2008 | 09:31 PM
Sharkey's Avatar
depending on your mods you may want to consider a stage 3 pcm.
Old Nov 4, 2008 | 09:34 PM
wet shot.
Same as Holley Pro or whatever they are, the big *******. They flow a ton of juice, but they draw a shitload of power and are overkill for 90% of people. They are also much more expensive (nearly $200 each new..) and are more expensive to rebuild and require more attention to keep them perfect.
Love hearing that massive click when they engage though, sounds like a damn starter solenoid.
Old Nov 4, 2008 | 09:35 PM
BLAZIN07SS's Avatar
I'm too JDM for you
no, no, and no. haha
my solenoids are LOUD. haha
Old Nov 4, 2008 | 09:40 PM
Johnboy12358's Avatar
nitrous is so tempting
Old Nov 4, 2008 | 09:42 PM
BLAZIN07SS's Avatar
I'm too JDM for you
you have no idea. its like a crack addiction. even worse when you get a bottle heater
Old Nov 4, 2008 | 09:46 PM
o3nisoaso3's Avatar
2007 Cobalt SS S/C
Mods= CAI
Dry or Wet?
Recommended kit?
go with atleast a 50 wet shot
Old Nov 4, 2008 | 09:47 PM
I like the way this guy thinks
Old Nov 4, 2008 | 09:52 PM
JimzSS's Avatar
say its only used (haha) for 1/4 mile pulls, say 10 a month ,with a wet, 50 shot.
will the motor stay reliable?
would you need a tune ?
Old Nov 4, 2008 | 09:56 PM
95cam86roc's Avatar
subscribed
Old Nov 4, 2008 | 10:06 PM
exiged's Avatar
speaking of wich, do u have a high res pic of your sig?
Old Nov 4, 2008 | 10:11 PM
Very reliable if tuned correctly. 50 shot on a 2.9 or bigger and Stage 2 tune or milder, will be fine. Custom tune is always recommended, required for larger shots due to the advanced timing in the Stage tunes.
Old Nov 4, 2008 | 10:13 PM
SSdan's Avatar
Joe what you think about a 75 and taking 2 degrees out. I may
Old Nov 4, 2008 | 10:14 PM
JimzSS's Avatar
thanks Joe
Old Nov 4, 2008 | 10:16 PM
BLAZIN07SS's Avatar
I'm too JDM for you
no, sorry man
Old Nov 4, 2008 | 10:22 PM
Check it and see. Should be good, may need a little more than that from stage timing. It varies from car to car.
thanks Joe
Last edited by ItalianJoe1; Nov 4, 2008 at 10:22 PM. Reason: Automerged Doublepost
95cam86roc's Avatar
Whats your thoughts of putting a 50 shot to a car that has a 2.7, 60s and water/meth? N yes it has the other supporting mods.
Old Nov 4, 2008 | 10:25 PM
idunn's Avatar
100 shot
Old Nov 4, 2008 | 10:27 PM
SSdan's Avatar
I don't think I have stage timing anymore, it's tuned now
Old Nov 4, 2008 | 10:28 PM
If you have Meth, it should make it that much easier. Just log the car on the bottle, make sure your a/f stays where you want it and there is no knock, and you should be fine.
If you are tuned for meth, adjust for a/f on bottle with jetting though, so you don't run too rich on meth off bottle. A .01 size change in fuel jetting does a lot though, so it might be easier to add or take out a little nitrous if need be.
Old Nov 4, 2008 | 10:30 PM
95cam86roc's Avatar
The meth is tuned to the car. I thought that a 50 shot would be ok for "every now and then". I'm not talking about every day or even once a week. Just whenever needed like at the track.
So you do think it would be fine with meth?
Old Nov 4, 2008 | 10:35 PM
Sure, a 50 shot isn't that much. Just watch your wideband and knock, if anything looks or feels funny, back out of the spray.
