Not getting spark ... help !
Old Nov 3, 2012 | 02:20 PM
jfox's Avatar
just recently swapped heads on my 2005 lsj put it in time 1 tooth off and didnt feel like doing it myself due to the wonderful pa weather so i took it to the chevy dealership to have them put it in time ... before i took it there it ran but ran rough now they have gotton me for almost 500$ to put the damn thing in time and on top of it, it is no longer getting spark. i just put new plugs in it, where should i start on trying to figure out why its not getting spark , cant afford to pay the stealership any more money to fix this .... it has to be something stupid
Old Nov 3, 2012 | 02:24 PM
nhanson's Avatar
Make sure all sensors are plugged in. Check for codes
Old Nov 3, 2012 | 02:35 PM
Tjolley's Avatar
crank sensor...
Old Nov 3, 2012 | 02:57 PM
bluebalt07's Avatar
Check connections and grounds first I'd say
Old Nov 3, 2012 | 03:22 PM
mrbelvedere's Avatar
tell them it ran when it came in and they need to find and fix what they messed up
there are to plugs that are the same i think it is the coil pack harness and the throttle plate if they mixed those up it wont fire
Old Nov 4, 2012 | 01:04 AM
jfox's Avatar
Originally Posted by Tjolley
crank sensor...
what would i need to do to the crank sensor ?
Old Nov 4, 2012 | 01:05 AM
jfox's Avatar
do you know of any other grounds other then the one on the valve cover that i could check thats the only one i know of and everything is plugged in
Old Nov 4, 2012 | 08:58 AM
the crank sensor is right above the starter
Old Nov 4, 2012 | 02:23 PM
jfox's Avatar
i just ran codes on it and the only one it came back with was pcm keep alive memory , would that mean the pcm needs replaced?
DarrenGC
Dec 24, 2021 01:55 PM
717ssbalt
Oct 2, 2015 04:01 PM
CobaltSS 16
Sep 29, 2015 01:53 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
Getaway_Driver
Sep 8, 2015 09:41 AM
