'Nother Shopping List
Old Mar 10, 2008 | 03:45 PM
They call me 'E''s Avatar
Ok so let me get this straight for my worrisome ass.
My plan is to skip stage II and go for just equivalent mods + dyno tune.
As far as I'm aware, I'll be needing...
Pulley (2.85 sound good?) http://www.smoothflowpulleys.com/Stage2.html
Injectors (Thinking 60's) http://www.zzperformance.com/cobalt_...=578&catid=143
Shorter belt (Hoping I can find that seperatly somewhere) http://www.crateenginedepot.com/stor...3-P1592C0.aspx
Spark Plugs (Can't remember the name, the ones everyone says to get) http://www.zzperformance.com/cobalt_...=490&catid=143
***** I'VE MISSED SO FAR*
Injector Harness http://www.zzperformance.com/cobalt_...ts1.php?id=516
Hub for the smaller pulley (included with nates pulley)
Cooling (didn't really forget it, but yeah)
Puller https://www.zzperformance.com/cobalt...=199&catid=142
And a custom dyno tune from my local tuner shop.
I KNOW I am missing something. So let me have it :E
And yes, I know, "search, *******!"
But hey, I never get to make a new thread
EDIT: Got all the pieces of the puzzle together, I believe. I'll do the cooling a wee bit later.
Old Mar 10, 2008 | 03:46 PM
SmOKe JeNsOn's Avatar
You can buy the stage 2 belt seperately at a dealership in parts thats what I did
Old Mar 10, 2008 | 03:49 PM
Excellent, thank you.
Old Mar 10, 2008 | 03:50 PM
Area47's Avatar
Rent me! per hour
bkr7e is the ngk number
stock number
6097
Old Mar 10, 2008 | 03:51 PM
stock number
6097
Outstanding, the ever helpful Area47
Jimmys2007CobaltSS/C's Avatar
wil it be cheaper then the stg 2 kit?
Old Mar 10, 2008 | 03:52 PM
Immortal Technique's Avatar
Where is a good price range for a tune?
Old Mar 10, 2008 | 03:53 PM
Rangerondubz's Avatar
Make sure you get the correct injector harness for the type of injector your going with
Old Mar 10, 2008 | 03:54 PM
Irrevalent, considering every GM dealer within 60 miles of me either says "We don't do that" or "What is a stage II..."
Besides, word on the 'street' is you get more power, safer, cheaper, going about it this way.
You will also need a pulley puller if your doing it yourself and a hub/pulley setup, not just the pulley
Old Mar 10, 2008 | 03:55 PM
Arr, that rings a bell. That I'll search for.
I can do the pulley myself, but I might just have the tuner shop do it, dunno. Do you know offhand if Nate does the hub/pulley assembly or just the pulley? And if not, where the **** do I get a hub D:
Old Mar 10, 2008 | 03:56 PM
tREBs's Avatar
if u really wanted some extra cooling go with a cobra H/E butother then that i think everyone else has everything u need covered! good luck
Old Mar 10, 2008 | 03:59 PM
I'll be getting cooling mods sooner or later, I just want to get the basic upgrades first. IIRC 2.85 shouldn't need cooling... I think.
Old Mar 10, 2008 | 04:01 PM
Cooling is always a good thing. Plan on investing in a cobra h/e.
Also you will need a hub/pulley combo, ZZP has them for $100 and im not sur how much nates are, check the supporting vendors section.
stonny9's Avatar
Look in the forsale section for some cheap new/used parts.
Old Mar 10, 2008 | 04:03 PM
tREBs's Avatar
buy a pulley from nate, strongly suggested, i got mine (2.9) shipped to my door (canada) all for $60 and its quality work...
Gotcha.
And I'll peek in our classifieds as well.
I was planning on going with Nates already
Last edited by They call me 'E'; Mar 10, 2008 at 04:03 PM. Reason: Automerged Doublepost
Old Mar 10, 2008 | 04:06 PM
stonny9's Avatar
some parts forsale
https://www.cobaltss.net/forums/parts-66/fs-tons-parts-60lbers-2-7-etc-look-100574/
edit: I dont know him
Old Mar 10, 2008 | 04:23 PM
Here is your shopping list:
Injectors
Injector Harness
Use "Step TWO" of THIS howto, for the injector install
GM Stage 2 belt
Modular Pulley System
ZZP Pulley Puller
You can follow THIS howto for the pulley change.
And the plugs that Area stated that can be picked up at a local Napa store
Edit:
Cobra H/E
Cobra H/E Brackets
You will also need hose and misc fitting's, read THIS howto for the fitting and install
Last edited by Rangerondubz; Mar 10, 2008 at 04:30 PM. Reason: Automerged Doublepost
Old Mar 10, 2008 | 04:31 PM
Injectors
Injector Harness
GM Stage 2 belt
ZZP Pulley Puller
Edit:
Cobra H/E
Cobra H/E Brackets
Pretty much what I edited into my OP, except I'll be going with Nates hub/pulley assy. Lemme see who's cheaper as far as that belt goes between CED and ZZP.
Thanks for the effort that took though, I do appreciate it ;o
Old Mar 10, 2008 | 06:01 PM
zakre's Avatar
stock number
6097
are those the one step colder or two steps? I want to get the two step colder iridiums.
Old Mar 10, 2008 | 06:05 PM
nherbst454's Avatar
My complete pulley systems (stainless steel hub, billet aluminum pulley, stainless hardware, and an allen wrench) are 90.00 for machined finish or 95.00 for polished. I also offer a pulley puller/install tool to purchase for 90.00 or rent for 42.00 including pre-paid return postage.
Nate
Old Mar 10, 2008 | 07:11 PM
You should be seeing an order within the next week or so Nate. I plan on purchasing the 2.85 pulley/hub combo.
RaginChopsuey
Oct 27, 2015 01:27 PM
patooyee
Oct 15, 2015 05:11 PM
SSLOW06
Oct 1, 2015 07:21 PM
dieGone
Oct 1, 2015 06:27 PM
