Odd dyno problem
Old Apr 18, 2008 | 05:04 AM
Rodimus_Prime's Avatar
Odd dyno problem
At about 5600, its shooting massively rich and killing about 20hp on the dyno sheet then it climbs back up.
Looks like I was tripping the Cat overtemp protection, I turned the thresholds up to 1800 and it didnt seem to be as bad but its still doing something at 5600 thats cutting power
Old Apr 18, 2008 | 08:09 AM
2K5SS/SC?'s Avatar
Do you have any datalogs? Some printscreens might help out. Also, what are your mods?
Old Apr 18, 2008 | 09:51 AM
only mod to the car is GM stage 2, everything else was removed and put back to factory
i have 2 logs one before and after I shut off the COT
It was rediculously hot, never seen temps that high
Old Apr 18, 2008 | 10:21 AM
2K5SS/SC?'s Avatar
If you have the stock cat is probably is clogged and on it's way out then. The car will start to stumble, then it'll run like total **** eventually. Pull the downpipe and check it out.
Old Apr 18, 2008 | 12:18 PM
wouldnt surprise me, retards at GM have this thing so ridiculously rich
Old Apr 18, 2008 | 12:34 PM
2K5SS/SC?'s Avatar
Super rich tunes can tear up that cat real quick. Don't worry it happened to me too back in the day!
Old Apr 18, 2008 | 06:03 PM
Well another solution is to make more power so that the run is over faster and the temps dont get so high lol
Old Apr 18, 2008 | 06:04 PM
Area47's Avatar
Rent me! per hour
shut off the COT.
Old Apr 18, 2008 | 06:06 PM
I did, the problem wasnt quite fixed, something is happening at 5600 and its cutting power
Old Apr 18, 2008 | 06:19 PM
Area47's Avatar
Rent me! per hour
set both numbers 0, set the temps to 7405.
turn off piston protection.
Old Apr 19, 2008 | 10:26 AM
piston protection is set at 3600, not 5600, theres no difference at 3600
what both numbers are you talking about?
Jan 12, 2016 12:01 AM
maliki778
Oct 1, 2015 07:39 PM
Sep 27, 2015 08:53 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
