Official Turbo LSJ thread!!!
Old 08-24-2011, 06:16 PM
  #251
Frew's Avatar
I for one could car less about going to the track, I would rather have street bragging right them a grenaded lsj trans
Old 08-24-2011, 07:27 PM
  #252
slawson0042's Avatar
Originally Posted by SCcobaltSS
Not sure about the harness I used my LSJ alternator.. The bolts from the LSJ will not work unless you have a 1" steel spacer between the head of the bolt and the alternator. LSJ bolts are 1" longer due to the tensioner bracket.
Thanks I thought I would need new bolts. I'll just get them from gm. Anyone have any input on the harness?
Old 08-24-2011, 08:42 PM
  #253
Dr.Balt407's Avatar
ive got pix!...... soon to come cuz im eating.
Old 08-24-2011, 09:09 PM
  #254
burstss's Avatar
Hey I got mine down only thing I need now is I have a 2.4 throttle body on it that's 6 pin and my harness is a 8 pin lsj what do I ge for that
Old 08-24-2011, 10:31 PM
  #255
jonathan923's Avatar
a 2.4 tb? what manifold it this? ^^^
welcome bra! haha
Old 08-24-2011, 11:28 PM
  #256
burstss's Avatar
welcome bra! haha
Ya the Saab intake manifold zzp turbo kit said I needed a tb off a 2.4
Old 08-24-2011, 11:29 PM
  #257
burstss's Avatar
welcome bra! haha
It's the modified zzp Saab intake manifold and they told Leto get a 2.4 throttle body cause my lsj throttle body don't fit and now I need the adapter fro
My lsj throttle body harness to connect this 2.4 tb
Old 08-25-2011, 01:11 AM
  #258
EXsoccer1921's Avatar
same one i'm running
Old 08-25-2011, 06:29 AM
  #259
burstss's Avatar
How did u connect ur lsj harness into the 2.4 throttle body ??
Old 08-25-2011, 06:39 AM
  #260
donald's Avatar
jonathan how much did you end up spending on the hahn stage V set up cause i am looking at the stage 2 or 3 zzp turbo kit next year let me know
Old 08-25-2011, 07:09 AM
  #261
05Slowline's Avatar
you will need the 2.4 tb, shorter tb to intake mani bolts, and zzp's adapter for the pinout...did you get the kit or what?
Old 08-25-2011, 07:48 AM
  #262
Frew's Avatar
Does the 2.4throttle body and spacer come with the zzp complete turbo kit?
Old 08-25-2011, 08:13 AM
  #263
05Slowline's Avatar
don't need a spacer with the 2.4
Old 08-25-2011, 09:09 AM
  #264
zrated89's Avatar
considering a turbo is easier on the trans than a blower unless youre two stepping and brake boosting......... thats not really an excuse but continue on street racer
Old 08-25-2011, 09:14 AM
  #265
I'm too JDM for you
BLAZIN07SS's Avatar
really? tell the guys who strip the teeth off third gear rolling into a pull that. lol some get lucky with these transmissions. some don't. fortunately i have been lucky so far
Old 08-25-2011, 09:16 AM
  #266
zrated89's Avatar
i was more so talking about launching with a turbo vs a blower. If youre running 30psi and start pulling like a jet engine while going into boost in third after switching gears than i can see that being a possibility but very unlikely
Old 08-25-2011, 09:24 AM
  #267
INFE's Avatar
Lol I distroyed 3rd gear with a turbo! What are you talking about!
Old 08-25-2011, 09:28 AM
  #268
zrated89's Avatar
i believe you i was talking about launching though
Old 08-25-2011, 09:31 AM
  #269
INFE's Avatar
I did a pull 1-2-3 and boom. From a dead stop.
Old 08-25-2011, 09:36 AM
  #270
zrated89's Avatar
Yea third is definately the weakest link in our trans. Thats why i have a spare sitting on my porch for when my slicks go on
Old 08-25-2011, 09:57 AM
  #271
well i got alittle lucky and i got the deal with everything including extras stuff i needed for about 3200 but i got 1000 outta of my supercharger kit too. and that zzp turbo kit is great for what ive seen so far man
Old 08-25-2011, 10:19 AM
  #272
donald's Avatar
thats not bad whats the comparisson on the two i don't have a supercharger to sell because i am na but the stage 2 zzp is about 3000 with 60's and 2800 without but i was also gonna put rods,springs,cams,and hahn full 3 inch exhaust maybe wisco pistons not sure but i figues all together with stage 1 axels about 5 grand what do you think
Old 08-25-2011, 10:36 AM
  #273
well as far as i know the main difference between the two kits are the turbo setups. hahn using a s20g which is a relative small turbo compared to zzp's s252 which is considered a much larger turbo. also hahn uses internal waste gates while zzp uses external. also hahn turbo set up is good for a good reliable 360-380whp car. when you can make 400whp+ on zzps kit using same or less amaount of boost. although i know for 2.2s and 2.4s things change a bit since the horse power claims on there set ups havent been as high unless you do internal work as you plan too. but then again thats much more money to invest if you know what i mean. we have a local 2.4tc that is in the 250whp range on only about 7-10 psi i believe and also on stock internals. i think he has the zzp stage 2 turbo kit
Old 08-25-2011, 11:12 AM
  #274
donald's Avatar
is he on here but i know zzp said just with the stage 2 and nothing else it will put you up 100 hp and 150 for the stage 3 but if i go stage 3 then i will have to put a roll cage in my car to go to the track cause they are mandatory after you pass 11.999 at bradenton and i know other track are more **** about power to i know orlando if you pass 8.8 in the 8th mile you need a helmet so idk and is he automatic cause i am
where do you find the hahn turbo kit at
Old 08-25-2011, 11:32 AM
  #275
I'm too JDM for you
BLAZIN07SS's Avatar
his hahn turbo kit was used. your best bet is zzp. unless you are on slicks you are not getting anywhere near 11.99
Quick Reply: Official Turbo LSJ thread!!!
