Official Turbo LSJ thread!!!
Old 08-29-2011, 03:18 PM
  #326
startingline05's Avatar
Originally Posted by BumbleBee
What kind of power can you get out of a s256et with 60lb injectors and stock fuel pump?
roughly, is 330whp out of site?
you should really think about bigger injectors and getting off that stock fuel pump if you are gonna run that turbo.
if you plan on staying with the stock system and 60's you might as well not go that big for the turbo
Old 08-29-2011, 03:33 PM
  #327
BumbleBee's Avatar
It's just for now.
Old 08-29-2011, 03:59 PM
  #328
I'm too JDM for you
BLAZIN07SS's Avatar
i tuned a local lsj turbo to 372whp on 19psi with a gt3076r, 60's and stock fuel pump. injectors are at 94% injector duty cycle
Old 08-29-2011, 04:00 PM
  #329
EXsoccer1921's Avatar
if you plan on only making 330whp now and end up finally about 400-450 i would go with a 252. 80s and a different pump.
Old 08-29-2011, 04:02 PM
  #330
BumbleBee's Avatar
Thanks, what I was looking for.
I just need my car back from the shop, been there too long and don't have time to wait for a fuel pump and injectors to ship right now.
Roger that, I'll be changing it up. I've had a few different turbos but ended up using the 256et. We will see.
Old 08-29-2011, 04:17 PM
  #331
jonathan923's Avatar
Originally Posted by slawson0042
i saved it. james just called and sold all my sc parts for me. i cant wait to get this on, although with my luck the clutch will grenade as soon as i do the first pull
what clutch are you on?
Old 08-29-2011, 04:30 PM
  #332
256et will work just fine. 252 will spool up slightly faster but if you'd have to go buy it then its not worth it. if you can get your hands on a 259 then get it with the billet wheel. you'll see same spool as a 256 or 252 but be able to make more power. people say my comparison sucks but w/e heres the difference a billet wheel makes
Ryan's car:
non billet s262
ported head
race gas
~490whp on 20psi
My car:
billet wheel s262
unported head
91octane
443whp on 20psi
Old 08-29-2011, 06:10 PM
  #333
Frew's Avatar
Josh, where does that gt30 fit in with the borg warner s-series? Like around a 252 et?
Old 08-29-2011, 06:31 PM
  #334
57mm inducer, 76mm exducer. it'd be closer to a 256 but 1mm larger inducer, and 256 has an 80mm exducer. then you have your different turbine housings that come in to play
Old 08-29-2011, 06:43 PM
  #335
Frew's Avatar
I see, thanks
Old 08-29-2011, 06:50 PM
  #336
a gtx3076 still may be better though, because bullseye doesn't make billet wheels untill 59mm. gtx is billet 58mm inducer wheel, oil and water cooled, dual ball bearing. can even get a .63 a/r T3 turbine housing with a vband exit. full spool around 3.5-4k rpms
Old 08-30-2011, 06:05 AM
  #337
BlkWdoSS's Avatar
Im turbo lol my build:
S366xl (too big lol)
80s
Custom IC piping
RD Fabs intake mani
Custom exhaust mani (I got my hands on it from USMCFieldMP)
Modified 3" DP and Hahn 3" catback
AEM Tru boost, Wideband, and EGT
Mishimoto Intercooler
DSM 1G BOV
TurboSmart Wastegate
AEM FPR
No dyno yet, turbo is extremely laggy, hence me saying its way too big. Considering trading for something smaller, definitely want to stay in the BW/Bullseye family though.
l8r,
PD
Old 08-30-2011, 07:14 AM
  #338
send an email to wild bill and tell him you want the .70 a/r T3 housing with the 74x65 wheel. it'll still support upper 600s mid 700s no problem and spool faster than ryans 366
Old 08-30-2011, 08:05 AM
  #339
INFE's Avatar
I just picked up this bad bitch can't wait to see how she runs!
PTE Billet BB 6262
Old 08-30-2011, 09:13 AM
  #340
that bitch looks sexy as fuuu^^^lol
Old 08-30-2011, 10:48 AM
  #341
slawson0042's Avatar
Stock clutch
Old 08-30-2011, 01:13 PM
  #342
Dr.Balt407's Avatar
PTE Billet BB 6262
O god no! so much win
ima have to upgrade soon.
Old 08-30-2011, 01:24 PM
  #343
SCcobaltSS's Avatar
^full spool 6k
Old 08-30-2011, 01:57 PM
  #344
INFE's Avatar
I'm shooting for like 4500rpm full spool. My 5857 hit 22psi by 3800rpm......
Old 08-30-2011, 02:10 PM
  #345
SCcobaltSS's Avatar
We'll see! What did your GT30R full spool to? You use to have a GT30R right? lol
Old 08-30-2011, 03:26 PM
  #346
Stock clutch
so am i lol. its been holding fine so far since january when i turbo swapped. i only step on it after 4k though and am not hard on it at all when daily driving.
Old 08-30-2011, 03:39 PM
  #347
INFE's Avatar
Yea a 3076 had a .60 a/r exhaust and spooled by 3500rpm. That turbo made good power for such a tiny turbo with a crappy cast wheel. Broke 400whp with it.
Old 08-30-2011, 03:49 PM
  #348
SCcobaltSS's Avatar
Cool. I have a 3076 with a .82 and it spools around 4.
Old 08-30-2011, 04:29 PM
  #349
slvr 04 rl's Avatar
was your 5857 BB or journal? cause this is the turbo i have, but its journal bearing.
Old 08-30-2011, 04:36 PM
  #350
INFE's Avatar
No it was BB. Im not a fan of the journal bearings.
Quick Reply: Official Turbo LSJ thread!!!
