Official TVS Thread!!!
Old 02-18-2016, 07:56 AM
  #10126
CobaltSS 16's Avatar
Originally Posted by cole3883
anyone have a TVS for sale?
Yes I do. I'll PM you.
Old 02-19-2016, 08:25 AM
  #10127
freakta's Avatar
Any pictures of 1900s in cars
Old 02-19-2016, 11:28 AM
  #10128
bubba_jay's Avatar
Didn't you buy one of the 1900s?
Old 02-19-2016, 12:43 PM
  #10129
Haven07's Avatar
I saw a couple on Facebook
Old 02-19-2016, 12:47 PM
  #10130
Administrator
Administrator
Staged07SS's Avatar
Tjolley has one.
Look him up.
Old 02-19-2016, 01:02 PM
  #10131
Slobodan Milošević
07blackg5's Avatar
I cant wait to get my tune finished up and dyno this spring.
Old 02-19-2016, 08:27 PM
  #10132
RooTBeeR's Avatar
Damn!! Where have u been man??
Put that blower to use already!!!
On the Legacy forum...funally got that POS going again.
Flex fuel kit and tune...fun ****! only 18psi though.
I will eventually. When i drop my LSJ into my LUV truck.
I've been on here for a while... pretty sure rootbeer was one of the first people to get a tvs. every pic I've seen he's posted, the tvs is on a desk, his seat or trunk tho #makesanicepaperweight
hilarious i was thinking the same
It used to be on the car, i swear!
This is why i took it off, along with having to get the car to pass smog.
Coupler went bad. Got it replaced, but by that time, car was already totaled.
Old 02-22-2016, 09:08 PM
  #10133
Haven07's Avatar
Anyone know how much oil the tvs 1320 takes and what brand is recommended?
Old 02-23-2016, 01:17 AM
  #10134
06ssvictoryred's Avatar
[QUOTE=freakta;7593327]Any pictures of 1900s in cars[/
This is when I first installed in December looks alittle different with the bumper back on the bleed line on for the option b and the fuel lab with a gauge on all that have to take an updated pic of it zzp coils soon too
The following 3 users liked this post by 06ssvictoryred:
freakta (02-26-2016), JapEatr (03-01-2016), RooTBeeR (03-05-2016)
Old 02-23-2016, 07:17 AM
  #10135
Administrator
Administrator
Staged07SS's Avatar
Brand GM.
Oil fill amounts can be found on Eatons site if you dig far enough.
Old 02-23-2016, 12:28 PM
  #10136
Haven07's Avatar
I have all that! I'm very tempted by your rims though...
Old 02-23-2016, 12:45 PM
  #10137
rrob5382's Avatar
I need that tvs haha, too bad I have no money for it right now
Old 03-01-2016, 01:57 PM
  #10138
South Central *********
JapEatr's Avatar
[QUOTE=06ssvictoryred;7593882]
where did you find the silicone upper rad hose?
Old 03-01-2016, 01:59 PM
  #10139
Slobodan Milošević
07blackg5's Avatar
Looks like a universal piece. You can see how kinked it is on the front side of the snout
Old 03-15-2016, 10:06 AM
  #10140
jdbaugh1's Avatar
Anyone here do methanol/water injection for their TVS? I only have 91 octane available and even with some good Lucas octane booster I am still getting some knock (2.9" pulley with 10:1 compression pistons). I was just wondering where you setup the nozzle, what kind of system you have, and how effective it seems to be.
I have already ordered a DVC-30 Devilsown methanol/water injection system but I have not received it in yet. I would try it with just water but I don't want my tank to freeze in the winter so I am thinking about either going with a good low additive windshield washer fluid with a decent meth/water ratio or eventually mixing my own.
TVS 2.2 L61- 2.9" pulley - 10:1 compression
Old 03-15-2016, 11:36 AM
  #10141
Slobodan Milošević
07blackg5's Avatar
how much timing are you running?
Old 03-15-2016, 12:03 PM
  #10142
jdbaugh1's Avatar
Well the knock goes away at about 15 to 14 degrees, sometimes it will dip clear to 11 with knock sensor plugged in. Really only happens under high load conditions. It robs some serious power having the timing down there.
Old 03-15-2016, 08:35 PM
  #10143
Got Bewst?
Bluelightning's Avatar
Like you I was stuck with only 91 on my TVS set up. I ran a 14gph nozzle with a 50/50 mix. The car loved it. But it's on the risky side because you're relying on the meth to keep the motor together with such an aggressive tune.. Now if you want to keep it conservative while making decent power run a 7gph nozzle. I recommend mixing your own and not running washer fluid. Those that would use washer fluid were adding bottles of Heet to it to add more methanol to it.
jdbaugh1 (03-16-2016)
Old 03-16-2016, 08:09 AM
  #10144
jdbaugh1's Avatar
Did you have a progressive system or all at once? What boost pressure did you have it kick on at?
With the washer fluid I think I can find up to maybe 35% methanol. The people you knew that were adding heet do you know if they needed to or they just wanted to get closer to that 50:50 mark? There are considerable cooling advantages with just water. From what I have read, the more methanol you add to the mix the more fuel you have to pull and the greater your chances of grenading the engine if something malfunctions.
Old 03-16-2016, 01:34 PM
  #10145
Got Bewst?
I just had the stage 1 kit that had a pressure switch. I had it come on at 10psi.
If cooling is all you are looking for then washer fluid or just water is fine. The added methanol will allow for a more aggressive tune. Guys would add Heet because they wanted to get closer to the 50/50 mark. Yes the more methanol you run you will have to pull more fuel out of the tune. But if you are running something like a 7gph nozzle with a tune that isn't on the ragged edge and they meth fails, it gives you a much greater cushion to catch it before any damage happens. The biggest thing to running meth is to have monitoring systems so you know all is well. Wideband, interceptor with the leds set for knock retard and an LED light when the pump would come on is what I ran.
There are even better fail safe systems now that AEM makes that can cut boost or timing if the flow of meth falls down to a certain parameter. That's an option also
Old 03-17-2016, 07:12 PM
  #10146
jdbaugh1's Avatar
Where do you think the best location to have the nozzle is with the 1320 TVS?
Old 03-18-2016, 08:52 AM
  #10147
Ukchilll's Avatar
i always got knock when running 14 15 and 16 degree of ignition and couldn't get rid of it no matter what a tried i do use 99 ron fuel but the knock completely when i got up to around 19-22 degrees the car runs great now
but i only use a 3.1 pulley
Old 03-18-2016, 09:21 AM
  #10148
yellowsupercharged06's Avatar
E85 is the end all, be all. I got timing for days lol. If you cant get E85, i can always mail you a drum lmao
Old 03-18-2016, 09:48 AM
  #10149
Slobodan Milošević
07blackg5's Avatar
what do you peak timing at? and how high do you spin?
Old 03-18-2016, 10:08 AM
  #10150
Id have to look at my logs but the timing is mid-upper 20's. I havent driven much since October so i forget the specifics. i think my redline now is only like 7200 rpm that was because i was running out of fuel, i never changed it after the return style was put in. Ill start to look at it as it warms up and probably push the rpm out to 7400 ish.
thats all up to Paul though, he is the one who tunes it.
Quick Reply: Official TVS Thread!!!
