Official TVS Thread!!!
#7784
What PSI can I expect from "x" pulley? *note, this is with 2.5" exhaust and stock header/dp. Take off 1-3psi depending on exhaust components
70mm / 2.75" ~ 25 psi
75mm / 2.95" ~ 22.5 psi
80mm / 3.15" ~ 20 psi
85mm / 3.35" ~ 17.5 psi
89mm / 3.5" ~15psi
Per Area47, note this is with a higher redline w/ upgrade valvetrain: as a slight correction to the psi reference.
if you spin the motor high enough a 3.1 pulley will make 23psi. a 2.9 will make 25, and a 2.75 will make 26.5. 99% of the tvs owners will not spin their engines to 7900 to see this. i personally have seen 27psi out of the 2.75 ring
um, a 2.7" i guess
#7789
Bone stock LSJ Long block with 127k
TVS - 2.9 Pulley
80s
CTI Mid length - catless - megan catback
3" custom CAI
Option B - Dual pass - Griffin H/E (IAT2 maxed on 6th pull at 135* F. Highest temp recorded today)
e85
Out of fuel... hp was still climbing past 7500... -_-
100% IDC by 7100 RPM
108% IDC by 7500 RPM
22-23 mid - 25 peak by redline
19 PSI by 6500 - 21 PSI by 7500
This particular LSJ took extremely well to leaner fueling. First 5-6 pulls were 11.7-12.0 dynoing 330whp/279 ft lbs.
And 12.7-13.0 using the same advance above =
TVS - 2.9 Pulley
80s
3" custom CAI
e85
Gonna get more fuel and rpm out of the car and get back at it.
