"The OFFICIAL "Whose running a 2.7" pulley with GMPP Stage Kit" Thread
Old Sep 8, 2006 | 10:02 AM
R33P3R007's Avatar
360 L337 User
I think you summed it up
Old Sep 8, 2006 | 10:11 AM
SS_SC_Cobalt's Avatar
has anyone tried bumping our FP up to compensate for injector ratings? I dont have a FP gauge anyone know what we have for FP?
On my sunfire Eco I get 42-43psi idle and it bumps to 56 at WOT....
that would change the injector ratings definitely....
they usually rate the 42lb injectors at 43.5psi....
Old Sep 8, 2006 | 10:18 AM
BLKSS's Avatar
Originally Posted by patathSS
Ok.
The question at hand and the title of the thead refers to running a 2.7 WITH GM Stage kit. Not good idea. Both Denny and Shortbus have something different that that. Shortbus has his own tuning and Denny doesn't have the GM tune either. Besides, I thought he used a MAF-t to tune with?
And I ran a 2.6 with 42s using a MAF-t to tune. I don't really call 126% injector duty safe........
I agree. He did run the Maf-t when he had his 3.0. Now hes down to a 2.6 Hp tuner with the same injectors. I was only using it as an example.
Old Sep 8, 2006 | 10:21 AM
mken's Avatar
I don't get it, on the stage 2 tune, 2.8" pulley, CAI, and exhaust I was running incredibly rich, off the charts rich. Ignore the green run, a/f wasn't hooked up, the blue run was after a custom tune. The red run is the one with the above setup:
The guy tuning my car didn't give me any number in specific, he just told me my injectors where far from taxed when I asked him about them.
Old Sep 8, 2006 | 10:29 AM
distillion's Avatar
my tuner says the 42.5 injectors are fine with a 2.85 pulley, hes gonna chec them out when the car goes in for a tune.
Old Sep 8, 2006 | 10:43 AM
OniMirage's Avatar
finally dyno proof. thx for that.
edit: I take that back the run wasn't to 7000rpm ... still looking for dyno proof then
Old Sep 8, 2006 | 10:56 AM
R33P3R007's Avatar
360 L337 User
how do i get my dynos online like that. i have mine still in the dyno program on my home computer.
I plan on getting dynoed soon with my stage 2 2.9 setup and then stage 2 2.7. without any custom tuning. then I will decide about tuning from there.
Old Sep 8, 2006 | 11:00 AM
djt81185's Avatar
Originally Posted by max_boost
It is a cute sig, but there is more than one car with that setup getting throught the 1320 in less time than he is. :-)
with what like 7mph less trap speed right ....hehe tell em to run me on the streets...will look like reverse...btw the cobalt ss running my same setup last night went 13.4@108 w/ 2.2xx 60' on stock tires and stock clutch...booyah
Old Sep 8, 2006 | 11:02 AM
OniMirage's Avatar
there should be a print button ?!? but if not open the dyno push print screen open something like paint then paste the picture and save it
Old Sep 8, 2006 | 11:03 AM
djt81185's Avatar
Originally Posted by CTCOBALTSSS
Ok so basicaly it comes down to this.
42lb injectors are OK all the way down to a 2.6" pulley as long as you have a tune.
If you are just running the GM stage 2 tune 2.8" and 2.7" pulleys make you run lean around that 7,000 rpm mark and you are at max duty cycle. That's what I have gathered from all of this. Right??
No..technically anything under 2.9 isnt SAFE...past 100%idc u lose control of fuel injectors and risk damaging them...a 2.6 at 6500rpm with mft is 126%idc...pat and I both had same setup at same time.
114%idc on a 2.8 w/ 42.5lbers at 7000rpm
does it work ya kinda...is it safe...no...but like i said...its your car...just dont cry if/when the injectors fail.
Old Sep 8, 2006 | 11:37 AM
  #36
06black's Avatar
ugh....i still cant beleve people dont get what i'm saying 100%.
heres the trick...most of these set ups will totaly max the injecters at7k....if you bump the limiter past that with HPTuners then you most def dont!...
so heres my short version of my rant...
EVEN IF GOD TUNED YOUR CAR YOU DO NOT HAVE ENOUGH FUEL FOR A 2.8/2.7/2.
for the people who clame they do...i'm sorry..thats just not true,...keep an eye on your IDC's...if they go into the 90%'s...guess what!!!! your dont have enough FUEL!!!!!!
an injecter loose's its control ability around the 92% IDC.....
i have a feeling that you think jsut cuz its under 100% your fine....thats not rite!
Old Sep 8, 2006 | 11:55 AM
  #37
OniMirage's Avatar
gotcha
Old Sep 8, 2006 | 12:04 PM
  #38
yangee's Avatar
so with stage 2 and a 2.8 pulley what is the best injector??? and where the best place to find this injectors
thanks
Old Sep 8, 2006 | 12:11 PM
  #39
OniMirage's Avatar
someone needs to put up a FULL dyno (ie 7000 rpm pull) with afr and fuel duty cycle ratings. This way we can see where the injectors are maxing out so that we can look at the next step so we can safely mod these things.
Old Sep 8, 2006 | 12:12 PM
  #40
CTCOBALTSSS's Avatar
thanks
Well it sounds like 60lb injectors is the way to go with a 2.8" and smaller pulley.
That will be a must because everytime I race I definitely hit 7,000rpm
This freaking sucks. I wanted to slap on a 2.8" pulley before I tuned but now it sounds like that would be pointless. 60lb injectors are expensive. Damn it!
Old Sep 8, 2006 | 12:13 PM
  #41
R33P3R007's Avatar
360 L337 User
can a normal dyno shop note those for me. i am going to rev it up. they do A/f but what about duty cycle?
Old Sep 8, 2006 | 12:15 PM
  #42
OniMirage's Avatar
same and with noone showing a full dyno pull we cant see where the issue starts. we would also need to have someone do it that has other mods ie: intake exhaust setup
Old Sep 8, 2006 | 12:16 PM
  #43
OniMirage's Avatar
they should be able to show it since they should be able to read what the computer is monitoring but it depends on their software capabilities
Old Sep 8, 2006 | 12:18 PM
  #44
R33P3R007's Avatar
360 L337 User
it's a brand new dyno. so i guess they can.
Old Sep 8, 2006 | 12:19 PM
  #45
djt81185's Avatar
ur afr may be safe now but in winter it def wont be...and over 80% compromises injector durability...why dont u guys believe us its simpe math. Plus ive seen countless logs posted...hell somewhere there are logs from my 2.6@6500 if u search around enough
btw spooner on rl forums saw 112%idc and 13:1 afr at 7000 rpm with gm st2 and a 2.8
Dan
Old Sep 8, 2006 | 12:23 PM
  #46
p7x's Avatar
p7x
Dan
ask 06SSg85, i think thats his handle. He was useing 60 lbers with S2 + 2.8 and the injectore duty cycle was 31%, he said he switched back to he's 42.5's which were running higher still under 80 %. But from all the ppl i have talked to about it most said, the 42.5 lbers is the safe edge for stage 2 + 2.8. But obviously a tune would be much better.
Old Sep 8, 2006 | 12:25 PM
  #47
djt81185's Avatar
How is a tune gonna alter the laws of physics...u can only deliver soo much fuel
10lb of **** in a 5lb bucket
put out a fire with a straw...etc
i give up on these people
  #48
OniMirage's Avatar
i dont really have time to search which is why I only refresh threads I have been in during the day until I get home. If you know of a dyno image that shows the lean issue please share and post a link so we can view
Old Sep 8, 2006 | 12:30 PM
  #49
Floridas Finest SS's Avatar
Well my ? is what is the % that a car with just GM Stage 2 no other mods, is at on the 42.5lb injectors? since its a 3" it has to be over 80% doesn't since a 2.8" puts it at about 114% right?
Old Sep 8, 2006 | 12:32 PM
  #50
p7x's Avatar
p7x
because a S2 car with a 2.8 still thinks it has a 3" on it, so fuel will be delievered accordingly, with a tune this can be be resolved. The question is can the injectors deliever enough fuel. You say "no" when I have talked to at least 2 ppl with HPT saying that a 2.8 with 42.5's doesnt max them out. So whos right and whos wrong and whats causes the diffrientation.
