Oil accumulator - where to tie in
I'm looking to put an oil accumulator on for high g turns, can someone point me to where the oil pressure access is? I'm having difficulty finding where the pressure circuit external tie-in is.
Thanks in advance.
Thanks in advance.
Cool, Thanks.
Now is it some weird metric fitting?
edit - looks like M12 x 1.75 is a bastard fitting to adapt to anything but 1/8" NPT..
Adding to this thread for future knowledge since I just went through all the research trying to find adapters for my accumulator. the Ecotec has 6 ports into the oil galley and each have a 12MMx1.75 thread pitch opening.
Dont bother shopping locally at Napa, or autozone or even a hydraulics fitting store. No one caries the very unusual 12mmx1.75 metric fitting adapter. thanks GM!
Here are the 4 options for adapters
Autometer adapter 12mmx1.75 to 1/8th NPT part number 2278 ~$10
http://www.autometer.com/cat_accesso...il.aspx?vid=62
Hahn adapter normally used for the turbo oil feel. 12mm x 1.75 to -6AN Part number H TZ-8086 ~$10
http://www.turbosystem.com/Hahn%20Ra...0pricelist.htm
ZZP 12mmx1.75 to -4AN fitting ~$17
http://www.zzperformance.com/cobalt_...=997&catid=150
Vulcan turbo adapter. 12mm1.75 to 1/8th NPT. ~$16
http://www.vulcanturbo.com/Turboothers.html
I looked at 2 accumulators. I decided on the masterlube accumulator over the Canton racing accusump for primarily cost reasons.
Canton recommends a -10AN oil line to the block and thought the 12mm x1.75 port would be too small. that would mean making an oil line T into 2 ports on the block
Masterlube uses a -6AN line and is the accumulator that was sold with the Ariel Atom so they have had success using their accumulator with the ecotec using this fitting.
Yes, a dry sump would be better, but it will run about $2000 from ARE for the pan and pump and lines. Since I have an Ariel Atom and a component of the frame is right where the AC compressor would be, I have to have someone make me a custom setup to attach the pump as well as custom lines. So another ~$1-2000
One of the Ariel's that had the ARE system added had the belt rip(since it is about 2 inches from the ground) on a rock, stop the oil pump and seize the engine. That is why Brammo stopped offering it on the Ariel's when they made them.
So in my case $400 accumulator for masterlube is a better choice for me
Thanks bolus, good to see you around again.
I'd given up on that project because I could not find a place to mount it.
But coincidentally I'm now needing the 1/8" fitting as I'm going to put in a sending unit to send to a signal to my Traqmate to log oil pressure vs g's vs were on track. So I'll be able to, at least log under what condition(s) what is happening where, when and why.
qwikredline- Does the LE5 pan have (basically) the same exterior dimensions/outline. We've got some real close quarter to frame issues.
Curious about the less capacity, found out that hardly anything above 6.5 qts will find it's way into the catch can.
le5 pan is a direct bolt on. it seems that you would run out of power steering motor, before you hit the limit of the lsj pan in your average horsepower lsj
So I have a Hahn super20G kit with a built engine and its in a 1400 lbs car. I added strengthened uprights for big slicks so it will be taking turns >2 g's Hence the concern about starving the oil pump. (plus no power steering )
Scratching head... at last event at Infineon max left/right loading was 2.3xg, max braking was 1.38g. Do I not need to worry about high g loading, especially in RH turns?
No PS pump so no worries there..
edit.. too slow with keys..
Looks like a good place.. careful with clamps as not to distort can..
Area - it's amazing what big timing did to wake this motor up..
Are you mounting hose on opposite end ie away from pump? You should have pretty clear access to the far left rear plug.
There are 6 ports to the oil galley. 3 on the back and 3 on the front. I havent decided on which one I might use. With the intake and exhaust manifolds I have all of them are easy to get to. The turbo oil feed is on the rear right most one now.
correct the LE5 pan holds less oil coz the LSJ had to hold more to satisfy EU extended oil life requirements that the USA do not need.
bolus - as I understand it you'll want to put the reserve oil discharge as far away from the pump as possible as that will be the first place to die (farthest from pump.) Turbo far forward (closest to the pump) is a good thing.
qwik - so same but deeper? or is that why it works better? We have external clearance/fitment issues. But that'd be something to try as a possible upgrade next time engine comes out for off season renew. Will know more when I log g vs oil pressure data at various tracks. Have you found a magic RH threshold?
Fortunately Laguna Seca, Infineon and Cal Speedway are predominately LH sustained turns. Buttonwillow CW and Spring Mt are high RH g turns.
part number 12578196
(37)
Interesting, here is the Hahn block adapter on the left and the autometer on the right. Looks like I'll be using the autometer since it has a much wider opening.
The accumulator fits there but the way.
By the way, I'm having Tom make me a remote oil cooler / filter kit. Here is the adapter for the filter.
This is for the accumulator though. I want oil to dump into the engine as fast as possible if there is loss of oil pressure
(my turbo oil feed is using his part though)
Bolus thats a nicely fabbed remote filter adaptor
different pan shape internally but subtle. Not the baffle. but its different too....The LE5 pan I sent Dennis is new and 100% complete. Bolt on. shave alternator boss maybe for atom
That makes sense and Tom did hook up my turbo feed closest to the pump. But since oil isn't that compressible wouldn't the pressure drop instantly throughout the engine rather than progressively if the pump sees air?
So it is a different pan or just the baffle? Because the baffle is only $8
(37)
(37)
Looks cool.
I'd have roll bar attachment interference issues, so that'd be a no-go for me. Banking on the pan to eliminate the need.
I gave up on Hahn they don't answer the phone..
Internal design is different. Will know more after replacement and test data collected.
May be forced to run Laguna Seca so I'll have data before and after.. the humanity..
