oil in cai, tb and supercharger?!?!
Old Oct 4, 2009 | 02:19 PM
06cobalt_ss's Avatar
Exclamation oil in cai, tb and supercharger?!?!
my car started to sputter and stall when i hit traffic lights so i figured it was a clogged cold air intake. so i removed the intake to clean it and i discovered oil in my intake and tb as well as the supercharger. i found out the oil is coming from the hose that attaches to the cold air intake and runs to the back of the motor and connects in to the motor. what could be causing that to happen. oil was just pooling up in my cai and being sucked into the blower. how could i fix this? any suggestions? thanks guys
Old Oct 4, 2009 | 02:21 PM
Bl4des's Avatar
get an oil catch can
Old Oct 4, 2009 | 02:23 PM
whats an oil catch can? y is there oil in there to begin with? my car has almost 70k on it and this has never been a issue. i wanna fix the problem itself. i never had an oil catch can and the car ran fine so y would i need one now?
Old Oct 4, 2009 | 02:25 PM
Bl4des's Avatar
that line is there to release crank case pressure and oil will come through it you can stop that but you get an oil catch can so it stops going into your intake you can make a small cheap one with a filter from a air compressor
Old Oct 4, 2009 | 02:27 PM
ok so how can i make one or buy one to rid my self of this problem? also does this have any neg effects on my car? meaning is the oil going to **** my car up?
Old Oct 4, 2009 | 02:35 PM
auggie_ss_phx's Avatar
i spend under 7 buck on this one
Bl4des's Avatar
^yeah that is what you want to make
search for how to home depot oil catch can on google and you will find what you need to do
Old Oct 4, 2009 | 02:44 PM
where did you get that?
Old Oct 4, 2009 | 03:50 PM
i got mine from harborfreight as Bl4des said its just an filter from a air compressor
Old Oct 4, 2009 | 03:54 PM
Bl4des's Avatar
you can get it at like home depot or lowes
but i would get barbed fittings not like the ones he has
Old Oct 4, 2009 | 03:56 PM
G85 SS's Avatar
You can do this. Or, there's a cheaper method.
Pull off your TB and intake and clean it out every 10K miles or so. That's what I do. I am also willing to bet that there is a whole **** ton of carbon build up in your throttle body(black stuff). Go to wal mart or any close by auto parts store and buy some throttle body cleaner. Clean out your TB, re-install and results will follow. IMO a catch can is a waste of money.
Never seen that one before. Looks pretty good. And cheap.
Old Oct 4, 2009 | 03:59 PM
MikeyB's Avatar
I have the same idea as that just different brand, works well
Old Oct 4, 2009 | 04:21 PM
yea its cheap and it works
Old Oct 4, 2009 | 04:36 PM
thanls bl4des, i just did this. got mine from home depot for 20 (air filter, 2 npt taps, 2 clamps) i hop this works. thank you bro
Old Oct 4, 2009 | 07:55 PM
leviticus88's Avatar
Lol, Thats exactly what I did and in the same place too. Works pretty good!
Old Oct 4, 2009 | 08:04 PM
Flatgod's Avatar
Except that the oil also make it's way all over your laminovas and cakes them full of **** as well.
Old Oct 4, 2009 | 08:23 PM
JHans5774's Avatar
I need to do this thanks for showin how is it easy to clean when it gets full?
Old Oct 4, 2009 | 08:30 PM
nicksredline's Avatar
when its full the little mettel nipple on the bottom presses up and the oil should run out.. you can recycle it back into the motor or just dump it ( in a safe place ofcourse lol.)
Old Oct 4, 2009 | 10:02 PM
yea it work great and its cheap to buy too
just like nick said,or you could just unscrew the container and empty it and srew it back up
Old Oct 4, 2009 | 10:10 PM
Bingo!
Old Oct 4, 2009 | 10:28 PM
Chase0224's Avatar
Got mine off ebay, 20 bucks shipped.
Its on the left.
Old Oct 5, 2009 | 05:05 PM
red06SC's Avatar
yeah
I cleaned mine yesterday, 65000 miles of buildup on them, they were pretty bad.
Jan 12, 2016 12:01 AM
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
z28addiction
Sep 28, 2015 12:03 AM
Sep 27, 2015 08:53 PM
