Oil Catch Can
Old Mar 6, 2009 | 08:14 PM
TommySSSC's Avatar
Originally Posted by rockkrawler628
its not expensive, its just an investment to insure oil doesn't get in the motor through the intake... **** up the throttle body/supercharger/motor
thats exactly what i need right now. i have some serious oil/carbon issues coming through the intake pressure, theres tons of that black crap in my tb and charger nad im sure motor. ive been all of a sudden getting missfire too so im sure its added to that. Spent all day today cleaning out my tb and charger. Wheres the best place to get one of these, thanks on the "how to"!
Old Mar 6, 2009 | 08:31 PM
SS/SCking's Avatar
Ebay IMO. I feel you dont need a real expensive one. Most on ebay are 25-35 shipped. I went and bought a breather filter and put it on there too.
Old Mar 6, 2009 | 09:19 PM
TommySSSC's Avatar
sorry if i sound like a newb on this, i can get a breather filter at auto zone right? ohh! sweet greddy ones are on ebay for 90 bucks!! what size do i need? could you post a good ideal ebay link for whihc one to get ss/scking?
Old Mar 6, 2009 | 10:11 PM
SS/SCking's Avatar
This is the one I have. Im using it horizontally attached to the passenger side strut tower.
Old Mar 6, 2009 | 10:15 PM
stealthy1ss's Avatar
I believe the reason you couldn't find the How To for this is because Anolomous (sp?) wrote one up but then got pissed at the forums and he probably deleted the thread.
Old Mar 6, 2009 | 10:21 PM
bikeboyben14's Avatar
ss/scking can you post your engine bay so we can see how you got it al setup
Old Mar 6, 2009 | 10:29 PM
SS/SCking's Avatar
Well there's no motor in my car at the moment but the can is mounted...lol
Old Mar 6, 2009 | 11:08 PM
Johnboy12358's Avatar
Post it up, I wanna see the catch can with no motor
Old Mar 7, 2009 | 04:38 AM
SS/SCking's Avatar
Ok Ill see if I cant get a pic tomorrow. Im going to the autorama today...
Old Mar 7, 2009 | 02:22 PM
krazycobalt's Avatar
This is where I was thinking about putting the catch can
Old Mar 7, 2009 | 03:23 PM
  #36
TommySSSC's Avatar
that looks like a good catch can to get king. is it better to pay more for that or should i just go to home depot and get that husky one? how did you bolt down your ebay one? it comes with an attachment part it looks like. use that and drill into something and bolt it?im assuming too that you are all new tubing right? they sell tube-tube connection right? so i can go from the engine --> filter attached by the top motor mount --> to the stock tubing before it get all crazy and bending, i can get like an attachment to connect it before the bend, like right behind the engine (above the header)
heres my idea
the blue is the new tubing that ill put in. the red box is the ebay oil catch can. then the gold little box is where i can reconnect the new tubing back to the stock tubing. theres that little flap of metal with those 2 prongs by the passenger strut tower (people attach the option b there) where you can attach the catch can. im thinking this works well
^^^i would be uneasy about the heat from the header coming up from there krazy
Old Mar 12, 2009 | 03:06 AM
  #37
So when these are connected, and the engine is running is there ny pressure in this line? Is there anything that I need to be aware of or not really? Just simply catches the oil
I'm wondering this because when it is installed, does the tubing have to be level acroos the engine bay or can it arc up a little. By the looks of the greddy one it arcs up, so am I going to have a problem with it sitting in the tubbing or running back to the valvue cover, etc? kinda why I was wondering if there is any pressure to move it along?
Old Mar 12, 2009 | 01:51 PM
  #38
leviticus88's Avatar
It's just air, running from the crankcase breather to your intake.
It has small amounts of oil in it, and that oil is not necceassrily good for your throttle body, sc, or motor. I don't think it has a ton of pressure behind it, but you should keep the lines as clean (short and simple) as possible. A little rise or fall in the line won't hurt.
Please correct if I am wrong!
Old Mar 12, 2009 | 02:05 PM
  #39
id like to see peoples installs on these if we can get some
Old Mar 12, 2009 | 02:56 PM
  #40
arkkornkid's Avatar
couldn't find a pic of my set-up so I just used the previous pic:
just do the home depot version, it works perfectly. See that white circle above the inlet of the SC, there's enough space to put it on the hose there and it will hang down and not touch anything....and it'll be away from the exhaust manifold.
Old Mar 12, 2009 | 03:16 PM
  #41
Old Mar 12, 2009 | 06:41 PM
  #42
well there was a greddy one that I was looking at (yeh yeh it is expensive, but i like the look. Dont want a cheap one even though they do the same thing) but it has a few small rises in the line. Is this goign to be a problem, here is a pic
http://www.racinglab.com/greddy-oil-tank-13500515.html
Old Mar 12, 2009 | 08:15 PM
  #43
EXsoccer1921's Avatar
you can change the fittings to 180* straight ones....
Old Mar 12, 2009 | 08:35 PM
  #44
qwikredline's Avatar
pm me for a solution....thanks
Old Mar 12, 2009 | 10:48 PM
  #45
Cc
Hey yeh i was takking a closer look at the Greddy catch can and it looks as if the fittings rotate and there wont be any hills per se. what do you have for a solution
Old Mar 12, 2009 | 10:55 PM
  #46
Black SS/SC 06's Avatar
i would pm him if i were you
Old Mar 12, 2009 | 11:02 PM
  #47
done done
Old Mar 13, 2009 | 01:16 PM
  #48
i just ordered a catch can off ebay 20 shipped ill get a write up and install once it arrives
Old Mar 13, 2009 | 01:28 PM
  #49
TommySSSC's Avatar
im still debating wether to get the ebay catch can or the small husky one from home depot. i know i get a lot of oil coming through there. i just cleaned my tb two weeks ago and i already see some more deposits in there. whats that little line of tubing that comes out of the bigger oil catch catch? does that show how much oil is in it? and we can mount it horizontally to get the same results right?
Old Mar 13, 2009 | 01:34 PM
  #50
ajm5036's Avatar
So is that the best spot? And what catch cans are you guys buying? I'm not spening more then 30 bucks. Any links?
