Oil Changes
Old Aug 24, 2005 | 11:59 AM
Corey's Avatar
Oil Changes
Has anyone yet tried to find the oil filter themselves...without a manual? It has to be the most awkward set up I have ever seen. Doing it myself would definately beena challenge seeing as how it took the guys at the local garage 20 minutes to locate it? Under the supercharger...on TOP!!! of the motor. Crazy. That is the ONLY thing I have to say wrong with this car so far. Everything else great...this....foolish!
Anyone agree?
Old Aug 24, 2005 | 07:38 PM
chevytech329's Avatar
I just changed my oil and filter last weekend on my SS/SC. Ive been reading how hard it is and blah blah blah. Well it took me about 2 minutes to change it. Not as hard as it looks.
1. locate the filter housing cap (black under the throttle body).
2. Unplug the map sensor to gain access.
3. Using a 1/2 inch drive ratchet, 12 inch extension and a 32 mm socket you can move a few hoses and lines out of the way and get right on it.
4. unscrew the cover.
5. set the ratchet and extension aside, reach under the supercharger with your right hand and lift the cover and filter out (use a rag to catch any dripping oil)
6. change the filter element
7. reinstall the filter and housing back on the engine and HAND start it.
8. Use the socket to retighten it (not too tight).
9. replug in the map sensor connector.
10. Add 6 1/2 quarts mobile 1
11. Enjoy
Jeff
SS/SC
red/red inserts
Old Aug 27, 2005 | 07:52 PM
Killjoy32's Avatar
its realy not that hard its all bs so u can bring it to them and they make the money
Old Aug 28, 2005 | 02:25 AM
CobaltSS422's Avatar
I'm gonna change my oil either tomorrow or next weekend but anyways I went to Wal-Mart and bought a 5 qt jug of Mobil 1 for $18.00 and then bought 2 1qt bottles for $3.96. Every auto parts store I went into wanted between $7.00-$8.00/qt for Mobil 1 and for a case of 6 was $31.00. to Wal-Mart for having cheap prices on oil. As far as the oil filter I've only seen 2 kinds.... Purolator and Fram. The purolator is like $4.00 at Wal-Mart and the Fram oil filter is $7.00. Just wondering what everyone else has been using who changes their own oil
Old Aug 30, 2005 | 12:06 PM
flobeelicious's Avatar
my dealer wanted 5 bucks for the acdelco filter. it looked better built than the fram.
why are you putting 6+ quarts in? the owners and service manual both say the oil capacity is 5 quarts. (going to change mine for the first time soon, might answer my own question)
costco has 6 packs of mobil 1 5w30 for around 23-24 bucks.
has anyone tried the mobil 1 0w30? says its supposed to give a bit better mileage than the 5w30, and it still meets the same gm standard 4718 that i've only seen 5w30 synthetics meet.
Old Aug 30, 2005 | 12:25 PM
R33P3R007's Avatar
360 L337 User
Anyone try Amsoil? I was wondering what everyones opinion was on using it. I hav 3600 miles on my SS/SC and was thinking of switching to it?
Old Aug 30, 2005 | 07:44 PM
phxSS's Avatar
Hell, I need 10w30 for my car, due to the consistant 110-115F temps here during the summer.
Old Aug 31, 2005 | 12:07 AM
from what other members have said who have changed their oil they have said they used 6.5qts. Anyone who has changed their oil did you jack the car up because i couldn't see driving our car up on those ramps . our cars seem a little too low to the ground for it?
Old Aug 31, 2005 | 01:09 AM
zinner's Avatar
Moderator Alumni
12) Drain out 1.5 quarts of oil.
The engine takes 5 quarts of oil, not 6.5.
Old Aug 31, 2005 | 12:46 PM
Corey's Avatar
I have let someone else do it....I used to use synthetic oil but with the cost fo fuel and everythign else these days...reg oil is gonna have to do! Its a lease at this point...so no matter really!
Anyone else been jacking their horses with pulley changes? I questioned it but never heard back...
Corey
Blue on Blue Inserts.......f&*king sweet
Old Aug 31, 2005 | 02:41 PM
alleycat58's Avatar
If you're that strapped for cash, I guess you have no choice. Synthetic must be really expensive in Canada. Around here, especially if you get the 5qt jug of Mobil 1 at Wal-Mart the difference in price between that and regular old oil is only a few dollars at most.
Old Sep 1, 2005 | 10:04 AM
Nightcrawler's Avatar
Corey
Synthetic is actually CHEAPER to use. It lasts two to three times as long as cheap regular oil. The revised newer Mobile 1 claims 15,000 miles. Alot of people don't get that. Sure, you pay more for it, but you don't have to change it nearly as often. It saves you the time of extra changes AND is cheaper.
Old Sep 4, 2005 | 12:05 PM
Unofficial How To.. Oil Change
Actually if you look in the manual it states 5.0qts WITH the oil filter!
I just changed my oil yesterday and was the very first time I have ever done an oil change on a car and I must say was the easiest thing to do. 30-45min job. Part of this was from chevytech329 but I'm gonna add to it because there is some stuff missing for it to be an actual how to....
ITEMS NEEDED TO CHANGE OIL:
1. Ratchet
2. 15mm Socket
3. 32mm Socket
4. 12in Extension for Ratchet
5. Jack
6. 2 Jack Stands
7. Oil Filter (I used a FRAM.. part number CH9018)
8. 6qts of Mobil 1 Oil (Get at Wal-Mart. 5qt jug for 18 bucks and 1 qts are 3.89)
9. Some rags if you make a mess
UNOFFICIAL HOW TO CHANGE YOUR OIL ON YOUR 2.0L SUPERCHARGED SS (people without supercharger the directions would be the same except you won't have to deal with the SC in the way):
1. Jack up the front end of your car. I put the jack in the middle (front) of the car. (Make sure you put something behind the rear tires and I also put the e-brake on).
2. Once car is jacked up I used 2 jack stands and placed 1 on each side of the car on the frame. You can't miss it. The frame rails run parallel with the tires.
3. Get a 15mm socket and ratchet. Get your oil pan.
4. Get under the car and locate the oil drain plug. It's towards the back of the oil pan.
5. Use the 15mm socket and ratchet to loosen the oil plug, BE CAREFUL if you unscrew it all the way, the oil really shoots out!
6. Once oil is drained put the oil plug back in, get the jack and jack up the car so you can take the jack stands out and then lower the car so you can easily work in the engine bay to get at the oil filter.
7. Locate the filter housing cap (black under the throttle body).
8. Unplug the map sensor to gain access.
9. Using a 1/2 inch drive ratchet, 12 inch extension and a 32 mm socket you can move a few hoses and lines out of the way and get right on it.
10. Unscrew the cover.
11. Set the ratchet and extension aside, reach under the supercharger with your right hand and lift the cover and filter out (use a rag to catch any dripping oil)
12. Change the filter element by pulling it off the cap and the new filter snaps into place on the cap.
13. Reinstall the filter and housing back on the engine and HAND start it.
14. Use the socket to retighten it (not too tight).
15. Plug in the map sensor connector.
16. You might want to add 6qts of Mobil 1 Oil. The manual states 5.0qts WITH the filter. The old oil I had drained out from the car I put back into the empty Mobil 1 containers I had. It filled 1 5qt jug to the top and about a half to 3/4 of a 1qt bottle.
GOOD LUCK!! It's actually really easy!!
Old Sep 4, 2005 | 12:43 PM
put a universal joint in your socket, extension setup to get the filter cap off, and you don't really need to move any hoses. just come at it at an angle from the side.
Old Sep 4, 2005 | 01:36 PM
The only thing I don't like coming in at an angle is you could possibly strip the nut part on the cover, it is plastic.
Old Sep 4, 2005 | 03:02 PM
codyss's Avatar
I just use a 1/2 drive socket with a 3/8 adapter all I have to do is unplug the sensor.
Old Sep 5, 2005 | 01:23 AM
05OrangeSS's Avatar
actually the oil pan holds 6.5 quarts of oil. If no one believes me call up your local dealership and ask them. Or just simply read your owners manual a little more carefully and you'll see it's 6.5, not 5 like the one guy said. If you'd like your motor to seize from lack of lubrication go ahead and use 5 quarts, but me personally I'm stickin to what it says, not what i hear from people on a forum
Old Sep 5, 2005 | 01:42 AM
ninja44's Avatar
I used 6 quatrs of oil on my last change and it reads overfull now. 5 - 5.5 is enough.
Old Sep 5, 2005 | 02:20 AM
Tofu's Avatar
Well I feel like an idiot. I just spent $60+ plus on oil, 1/2 drive 10 inch extension, mobil 1 5w30 oil, and the 32mm socket....I changed my oil and proceeded to log down the info in my extended warranty manual (along w/ the receipts) when I noticed a check-book looking manual tucked in one of the pockets. Low and behold it's full of free oil changes at the dealer and other service vouchers for getting extended warranty...I didn't know whether to be happy, or pissed at the moment lol.
Old Sep 5, 2005 | 09:58 AM
Proper oil fill????
Well after reading the owners manual, checking at work (i work at a chevy dealer) using
dealerworld and changing my own oil (been changing oil for 20+ years)...
I can tell you my car held 6.5 quarts.
was not quite sure at first (from reading what people on here wrote).. so I started
with 5 quarts (after a full oil change with the oil draining for 30 minutes), then started
adding oil 1/2 quart at a time untill the level was on the full mark.
Yup, 6.5 quarts just like it says. After driving it for 10 miles and let it sit over night
I rechecked it cold. Right on the full line.
HUmmmmm
Guess the manual was right.
gee imagine that.
My .02
Jeff
2005 SS/SC
Gm ASE Master Technician over 18 years
Old Sep 5, 2005 | 10:23 AM
mugencivicsi's Avatar
when i went to the dealership for the first oil change they put in 7.5L of oil......
total coast went like this
8l of mobile 1 = 8x10.5
Hour Rate = 10
Filter = 6.5
total coast at dealership 115.58
so i have now baught the filters from the dealership i got two for 13bucks
and i am goin to buy my oil from walley world (gotta love walmart)
Old Sep 5, 2005 | 12:22 PM
05OrangeSS's Avatar
Is it just me or are a majority of people who own this car handicaped or something. If your gonna come on here and spit out facts like you know what your talking about you might wanna research before you run your mouth. The GM mechanics that post on here and a very few select people on these forums seem to know what they are talking about. That's my .02 as well
Old Sep 7, 2005 | 12:26 AM
I put 6.5qts in when I did my oil change. So anyone else wants to put 5qts in and bust their engine go ahead like TheExorcist said. Car runs amazingly smooth with 6.5qts in it. Don't forget that oil filter needs to soak up with oil too!!!
Old Aug 19, 2006 | 12:33 PM
wikkymaster's Avatar
32mm socket to take off the oil filter cover? i think i used like a 1 1/4 socket last time, i have a 2.2 not sure if its different, the only reason i ask is because i am going to change my oil today and i dont have either of the sockets anymore so i will need to buy a new one...just want to make sure i buy the right one.... 32mm it is??
Old Aug 20, 2006 | 03:07 AM
Tomtwtwtw's Avatar
I used 1 1/4 on mine...I'm pretty sure they all use the same socket, but I'm not 100% on that.
