Oil and coolant in my intake FML
Old Dec 31, 2012 | 01:41 AM
Tjolley's Avatar
i see a build thread in the future!!!
Old Dec 31, 2012 | 01:55 AM
bykryder83's Avatar
^X2 lol
Old Dec 31, 2012 | 03:18 AM
Tjolley's Avatar
diamonds!!!!!! lol
Old Dec 31, 2012 | 07:25 PM
TheSandMan's Avatar
Leak down test showed 100% loss in cyl 1. I could hear hissing coming from the intake and the oil cap. I dont know if i should pull the head to look or just put in a used engine....
Old Dec 31, 2012 | 07:41 PM
Bluelightning's Avatar
Got Bewst?
For what it takes just pull the head. It doesn't take long.
Old Jan 1, 2013 | 12:23 AM
c130aviator's Avatar
Pulled my head in about 2 hours while messing around looking at stuff. Just pull it, you have to one way or the other.
Old Jan 1, 2013 | 12:36 AM
bykryder83's Avatar
Pull the head it's a very easy job and doesn't take long. As for buying a used lsj, don't because you don't really know how it was treated or maintained. I say pull the motor, tear her apart, buy diamonds(10:1 or 10.5:1) with total seal rings, new bearings from gm, oem or cometic head gasket, get block honed, arp head studs, new rod bolts, new cam bolts ect,throw it back together and have some fun!!!!
Old Jan 1, 2013 | 01:54 AM
BLAZIN07SS's Avatar
I'm too JDM for you
These ecotecs typically don't blow headgaskets. Broke a ring land or busted a sleeve. I put money on it
Old Jan 1, 2013 | 01:56 PM
getting my sleeved block back as soon as mrbelvedere picks it up from the machine shop. I have all the parts listed above for just such an install.
OP, I was almost ready to do what you were going to do with a long block but this is just more fun when you build it yourself.
Old Jan 1, 2013 | 06:19 PM
TheSandMan's Avatar
Yea I'm just going to tear into it and see what' exactly is going on. If it leads me to rebuild so be it. Pictures posted soon!!
Old Jan 13, 2013 | 10:20 PM
  #36
TheSandMan's Avatar
I'm thinking this is my problem. I see nothing else so far and I can't tell where the head gasket failed. Looks like I'm going pistons. Also
I found one if my tensioners in two pieces.
Old Jan 13, 2013 | 10:22 PM
  #37
mrbelvedere's Avatar
you wont be able to see if the ring land is gone until you pull the piston
GDS
Old Jan 13, 2013 | 10:31 PM
  #38
TheSandMan's Avatar
I was referring to the giant peice missing on the top of the piston near the cylinder wall. I think that's where I'm loosing all my pressure but either way I need to tear it down.
Old Jan 13, 2013 | 10:38 PM
  #39
if its what I think it is it isent much but it dosent take much that's not a tensioner by the way its a slider
GDS
Old Jan 13, 2013 | 10:47 PM
  #40
chris88z24's Avatar
How does this even happen? Do you romp on the car daily?
Old Jan 13, 2013 | 10:49 PM
  #41
DETONATION happens
GDS
Old Jan 13, 2013 | 10:50 PM
  #42
TheSandMan's Avatar
No. Not everyday it's actually been a long time since I have. I'm putting a list together of all the parts I need tonight for the rebuild as long as the sleeve is still ok. Does anyone know if I have to pull the timing cover to replace that tensioner?
Old Jan 13, 2013 | 10:59 PM
  #43
no you don't but your gonna have to to fix all the carnage under the cover and don't buy pistons thinking they are just drop in and roll if the bore isent within spec your fucked
GDS
Old Jan 13, 2013 | 11:03 PM
  #44
TheSandMan's Avatar
Anyone want to buy a cobalt... Runs like new
I guess I'll pull the piston and check the bore. If its in speck ill move forward if not, sleeves?
Old Jan 14, 2013 | 12:05 AM
  #45
turbosmart4's Avatar
Originally Posted by TheSandMan
Anyone want to buy a cobalt..with a sti swap.
Fixed.
Old Jan 14, 2013 | 12:09 AM
  #46
yup or bore it
GDS
Old Feb 4, 2013 | 03:49 PM
  #47
TheSandMan's Avatar
I just moved from Cleveland to newyork. I had to leave my car in Cleveland because of its condition. I had it towed to a Chevy dealer to have them finish the year down and rebuild the engine for me. They didn't even pull the car in the shop and told me my cylinder is oval and it's cheaper to buy an engine then to resleeve this one. I never measured or checked the cylinder so I don't know of this is true. I would like some opinions, buy complete engine, rebuild this one?
Old Feb 4, 2013 | 04:32 PM
  #48
they have the toolkit to resleeve the engine and cut the sleeve down in the car as for replacing the engine I would get a new one before I got a high milage used on the price wouldent be that different
Old Feb 4, 2013 | 04:45 PM
  #49
TheSandMan's Avatar
I found one with 45k miles for $2k
Old Feb 4, 2013 | 04:49 PM
  #50
jonathan923's Avatar
you took it to the dealer? get your wallet ready dude, its gona get raped..
