View Poll Results: JB Weld or Standard Aluminum Weld?
JB
18.18%
Standard
81.82%
Voters: 11. You may not vote on this poll
Oil Temp Bung
Old Aug 2, 2011 | 02:49 AM
insylem's Avatar
Question Oil Temp Bung
Hey Everyone,
I want to install a bung for a temp sensor in my oil pan.
Question is,
Should I have it welded, (It's an aluminum bung) into the oil pan,
or would JB Weld be sufficient?
Drilling a hole and JB Welding it, would be ALOT eayser
however would it hold sufficently? A large enough or
sudden leak and there goes the oil.
A Weld while being the more difficult way,
runs the risk of warping the oil pan? Aluminum welding
sometimes doesnt work from what I understand depending
on the alloy number. There is heat treatment to worry
about as well.
I had avehical years ago that had a crack jb welded
on the side of the engine that covered the timing chain,
and it held very well.
Opinions please.
Old Aug 2, 2011 | 03:49 AM
redcobalt07's Avatar
Don't half ass it. Do it right the first time.
Old Aug 2, 2011 | 10:04 AM
mrbelvedere's Avatar
dude you are in complete retard status if u use jb weld and welding the oil pan wont warp it
Old Aug 2, 2011 | 10:26 AM
metalmedic's Avatar
just get it welded it will be a lot better in the long run..
Old Aug 2, 2011 | 10:30 AM
07BoostedG5's Avatar
tap it.
Old Aug 2, 2011 | 02:03 PM
ben_gary's Avatar
don't JB it!
Old Aug 2, 2011 | 02:10 PM
iboost's Avatar
Originally Posted by 07BoostedG5
tap it.
This...
Old Aug 2, 2011 | 02:25 PM
Nacademus's Avatar
LOL. JB Trollin... too bad Elmer's Glue wasn't an option...
Old Aug 2, 2011 | 03:08 PM
insylem's Avatar
How about I use some Duct Tape instead?
Old Aug 2, 2011 | 03:11 PM
ItalianJoe1's Avatar
If you want, I have a spare LSJ oil pan, I can put a fitting in it for you and ship it to you, so you can just swap them out and sell off your old one. I've done a couple turbo drain fittings for local cars like that. Always, always weld it. JB weld is NOT a good way to put things together. Drill/tap if it's small, or weld it, but please don't try to epoxy a fitting into the oil system...
rhanes216213's Avatar
How about Super glue. I would tap or weld it. The only way to go.
Old Aug 2, 2011 | 03:35 PM
insylem's Avatar
Thanks for your offer, but I already purchased a spare LSJ oil pan from GMParts Direct. I wanted to have a spare in case I screw up.
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
Trav3480
Oct 1, 2015 08:17 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
z28addiction
Sep 28, 2015 12:03 AM
jmelton327
Sep 26, 2015 10:04 PM
