Is this ok??
Old Apr 29, 2008 | 01:09 PM
2FST4U's Avatar
Is this ok??
I just recently had the 2.8 pulley with 60lbs injectors installed on my 2.0 and now it louks (spelling) like a v8 or something. The RPM's dont move but my boost gauge moves just a hair up n down. Is this normal? Also just a note I am runnin a tad Rich.
Old Apr 29, 2008 | 01:12 PM
sehoublackss's Avatar
TUNE! You can't just slap this on *****-nilly. Get it done son.
Also check for leaks and if everything is sealed right.
Old Apr 29, 2008 | 01:16 PM
INFE's Avatar
damn im suprized it even runs without a tune.
Old Apr 29, 2008 | 01:17 PM
sick_ss/sc's Avatar
or booooooooooooooooommmmmmmmmmmmmm... bye bye ecotec..lol
invisible's Avatar
X2. If you try do drive it, you ARE going to blow something up.
Old Apr 29, 2008 | 01:21 PM
M-Dub's Avatar
2FST you need to tune it after those parts are installed.... I just got my 60's in Sunday and it needs tuning before you run it.... also take some carb or brake cleaner and spray it around the injector holes and listen for leaks... you will hear it suck the fluid inside.......
Call WickedSS and get it tuned ASAP!
Old Apr 29, 2008 | 01:39 PM
elecblue06's Avatar
either byebye # 4 or you have an exhaust leak some where bad..
Old Apr 29, 2008 | 02:23 PM
0redline6's Avatar
that made me lol
Old Apr 29, 2008 | 02:51 PM
2K5SS/SC?'s Avatar
Did wicked toon them in for you after you installed them? If not, you need to get on it! Also, check for vacuum leaks like MDub stated! No tune = BOOM!
Old Apr 29, 2008 | 03:24 PM
M-Dub's Avatar
If you aren't tuned your car is still under the impression that you are running 42s.... get it tuned ASAP!
The reason I state check for the leaks, is when Area47 and I did mine on Sunday the #2 injector wasn't seated all the way in... causing it to jump around at idle and when we sprayed the carb cleaner you can hear it sluuurp the fluid in...
Old Apr 30, 2008 | 11:45 AM
2FST4U's Avatar
I am tuned..Wicked said the tune looked perfect, so I will try the carb cleaner today and see if i have a leak
Old Apr 30, 2008 | 06:50 PM
TommySSSC's Avatar
would say you should of called me about it and i would of helped you out man, yet again my phone is STILL broke
Old May 1, 2008 | 11:26 AM
2FST4U's Avatar
Damn man fix that *****...lol
