OneCOLDBIZL272's Custom Oil Cooler Set-Up
Old Jun 21, 2010 | 07:57 PM
OneCOLDBIZL272's Avatar
This is one of the the little mod's out of a few to come that I did to my car, to get my car back to my standards of track ready again.
Cars oil system now contains 8.5qts of oil, and the temps have dropt alot on my build motor set-up.
This system cost me roughly $280-290 to put together.
Blaided lines are -10an
Old Jun 21, 2010 | 08:07 PM
ralliartist's Avatar
You already told me about this so I was kind of expecting a thread on it.
But, the LSJ already has an oil cooler. Although it does use the engine coolant to cool the oil. But, is it really necessary to go all out and install something like this? Are you doing more than drag racing? Are you doing road racing that is causing you to run much hotter temps than usual?
What kind of temperature drops have you seen?
Old Jun 21, 2010 | 08:25 PM
selfinfliction's Avatar
An oil temp cooler strapped to the condenser that gets as hot as the radiator, lowers temps on a car that already has an oil cooler on it?
maybe if this thing didn't already have a system built onto it, it would be useful... or if ralliartist said, if you were running hard on a road course or something... dunno, but i just don't see that lowering temps down, and i would be really curious how it effects your oil pressure.
Old Jun 21, 2010 | 08:31 PM
PRND3L's Avatar
IMO it would be better if it was mounted remotely, like on a frame rail or on the crash bumper. If anything, the extra oil in the system will keep temps down.
Old Jun 21, 2010 | 10:31 PM
I plan on road racing it, there is a 1/2 inch spaced between it and the radiator. And my temps with my motor build were 190-195, I'm not sure if it has to do with my higher compression, but since is done my temp is 180-183, and drop rapidly into the 170-178 when on in the pedal, the reason I located where I did was one, it's in the open part of the top grill for cooling, and two to see it threw the grill.
Temps drop for these reasons that I see I'm running now 8.5 from the stock fill of 6.5qrts. Two I'm using air to cool it not the 180* plus coolant bolted right on the hot motor. It has helped a lot more than I thought it was going to.
Its' spaced a 1/2inch away from the radiator, I have no ac condenser, ac is completely deleted.
Last edited by OneCOLDBIZL272; Jun 21, 2010 at 10:31 PM. Reason: Automerged Doublepost
Old Jun 21, 2010 | 10:33 PM
mrbelvedere's Avatar
the stock oil cooler isent that great and your welcome derik lol
Old Jun 21, 2010 | 10:40 PM
Thanks john! you gave me the ideal. I just made it happen I'm not the first to do this, cavy's doing LSJ Swaps are ditching the stock oil cooler, so are most ariel atoms from what I hear. cause they claim they suck.
Old Jun 21, 2010 | 10:45 PM
you are the first to do it that way and atoms are diching it becase it sucks
Old Jun 21, 2010 | 10:58 PM
sweet, I wasn't awear of me being the first to do it the way I did it, thats cool. heck my spend the money to buy this plate below that the cavy's and atoms are, when i can tape my stocker and bingo "FREEBIE" like jessie james monstor garage...lol
by the way pushing the fittings onto the braided line was a pita. lol
Last edited by OneCOLDBIZL272; Jun 21, 2010 at 10:58 PM. Reason: Automerged Doublepost
Old Jun 21, 2010 | 10:59 PM
Rodimus_Prime's Avatar
Thats the sqwirl right there and it was done months ago ^^^^^^^
Old Jun 21, 2010 | 11:00 PM
by doing it that way you keep the oil relief pressure spring in the system the other adapter dosent have it
Old Jun 21, 2010 | 11:01 PM
Omnigear's Avatar
if the oil is stayin at optimal range why cool it down some more? even though your running a car hard if it can keep up with the cooling demands.
jon meant I was the first to use the stock bracket and tap it, instead of using this bracket, like on this cavy pic above
Old Jun 21, 2010 | 11:04 PM
no **** wow you are observant i followed the build and it was done different by derik
convetional oil starts to break down at 180 synthetic starts at 190 and the only thing the stock cooler is good for is warming up the oil
Last edited by mrbelvedere; Jun 21, 2010 at 11:04 PM. Reason: Automerged Doublepost
Old Jun 21, 2010 | 11:10 PM
I plan on doing road racing in the future, and plus it was something to try. and ever since my motor build with my higher compression I've ran at 190-195ish and now I'm back to optimal temp levels. of 180* and lower if I get on it. I'm just trying to protect my investment in my motor a little more lol
I wish I had the time to follow other peoples build like I use to. These days I just don't have the time with everything going on with my car and other stuff in my life, I'm suprised I find the time for my car or this site.
Last edited by OneCOLDBIZL272; Jun 21, 2010 at 11:12 PM. Reason: Automerged Doublepost
Old Jun 22, 2010 | 06:12 AM
a small oil cooler like that dropped your coolant temps down 15 degrees
Old Jun 22, 2010 | 02:07 PM
To be honest yes it did, it's bigger than stock, main reason why it helped was for the extra oil the car takes to fill the system 8.5qrts now. this has way better cooling than the factory unit that I'm seeing. The small one is only temp I'm getting an 11"x 11"x 2" when there not on back order from the local race shop near me.
Old Jun 22, 2010 | 03:02 PM
if it changed it that much, that would be a big no go for me cause dropping down below 180 will close the tstat which means little to no flow of coolant to the turbo.
i just can't believe it made that much of a difference
Old Jun 22, 2010 | 03:27 PM
self it will make that big of a difference you should run that setup your oil temp is going to be higher because of the turbo and you will get plenty of coolant flow to the turbo mine has run 180 seince the day i bought the car new
Old Jun 22, 2010 | 03:56 PM
now you are just being ignorant. If the stock cooler was only good for warming up the coolant, then I'm pretty sure it wouldn't be there, and it wouldn't be called a cooler.
Props to you for doing something different OneCOLDBIZL272. And thanks for sharing it with the community. I'm sure this will be a great mod for some of the road racers out there.
Last edited by ralliartist; Jun 22, 2010 at 03:56 PM. Reason: Automerged Doublepost
Old Jun 22, 2010 | 04:21 PM
Yeah that be no good for you then
Old Jun 22, 2010 | 04:28 PM
I'm still on stock compression for the time being anyway. My coolant temps ran normal.
Old Jun 22, 2010 | 05:24 PM
no im not being ignorant it has more then 1 use it is not just a cooler its main purpose is to get the oil at runing temp faster and to try and keep it at a constant temp to help reduce oil burn off by doing those 2 things you help reduce the emiissions out put of the engine
Old Jun 22, 2010 | 06:44 PM
where is your turbo coolant tapped into?
Old Jun 22, 2010 | 11:23 PM
i dont have a turbo on mine but i am speaking from experience
