Only getting 3lbs of boost
Old Jul 7, 2016 | 05:25 PM
Jamie1234567's Avatar
Hi my 06 ss/sc CEL came on the other day and the car would only boost to 3lbs so I checked the code it was a boost solenoid malfunction so I picked up a new one replaced it and erased the code and still does the same thing so I drove it around a little bit never changed but I don't have a CEL anymore so what could this be? I took the hose off the actuator that leads to the solenoid and with that disconnected it makes normal boost 12.5 or something close to that but when that hose gets hooked back up to the actuator it makes 3 so I'm really stumped at what it could be since the solenoid is brand new any help will be appreciated thanks
Old Jul 8, 2016 | 12:19 AM
ItalianJoe1's Avatar
Could be a wiring fault to the solenoid holding it open. What was the specific code? Check for correct voltage/ground at the harness that connects to the solenoid itself.
Old Jul 8, 2016 | 06:38 AM
The code was p0033
Old Jul 8, 2016 | 11:27 AM
Viperoni's Avatar
Originally Posted by Jamie1234567
The code was p0033
Now that you have the code, this problem does happen to these SC cars.... the best way to search for answers on this form is actually by googling.
Type "cobaltss.net" and then the thing you want to search for into Google, just like this: https://www.google.com/search?q=p003...ltss.net+p0033
Old Jul 8, 2016 | 05:39 PM
If it's a circuit fault and you put a NEW solenoid on it, i'd suggest tracing the wiring and seeing that there's no spots where it has rubbed through or broken. It sounds as if the solenoid is pulling open all the time when it shouldn't be.
If you unplug the solenoid electrically, does it boost normally? Leaving the vacuum lines attached but pulling the plug on the solenoid.
Johnnie Olivares
Apr 23, 2016 07:23 PM
califcarm
Apr 22, 2016 10:54 PM
TxBlueBalt
Apr 20, 2016 12:57 AM
StrykerCC
Apr 17, 2016 08:29 AM
cooljake73
Apr 11, 2016 08:59 PM
