Option B 3/4" Hose
Window Licker
Option B 3/4" Hose
Option B guys, how the hell have you been routing your 3/4" hose to your t-fitting? There is no way in hell I am running mine right past my belt lol. There is absolutely no room there. And have you guys been using a 90 degree fitting to hook up to the t?
ive been wondering the same thing.... def no room with the TVS lol
Window Licker
it goes from the tank over the coolant hose to the engine and to the T fitting
only way i could think to route it
Window Licker
Awesome!!
haha yeah i dont really wanna do that. I cant have that hose in the way of a polished tvs. I was thinking of maybe bringing it down under the headlight and then over across the top of the fans but that would require more hose and probably the use of two 90 degree fittings, and im kinda iffy on using the 90's in the first place.
Still should be no where close to where the tvs pulley sits. the tvs is a much larger SC. It takes up hella space. Can you take a pic of your engine bay and post it?
Window Licker
mine is routed right pass the pulley haha ziptied to frame or whatever
i had it routed under the passenger head light and it wasnt gonna work for me. the headlight was angled up and when the hood was shut it was pretty close to digging into the headlight
ill get a pic, give me a few
This is how I did it for my flow through tank with two 3/4" hoses after another local member told me.
Remove passenger headlight. You feed the hose from the opt b tank through the hole for the washer fluid fill neck. Then fish it under the passenger plastic headlight bracket and it exits right by the radiator.
Or reverse the hose feeding and start from the radiator. There is plenty of room.
Window Licker
Thanks for postin up guys. Yeah i think I might try to do this ^. Route it under the headlight and then straight over top of the radiator. On the other hand, i might just cut some of the frame away like boostedg5 did haha. I dunno. I gotta look her over in the morning and figure out what i wanna do.
