ott stage 1
Quite a few people have it, and have all laid down similar numbers with the same mods. Most have been rate at 256~258 whp with a few cooling mods and exhuast. are there any questions that you have about the kit i could answer?
For some feedback i would pm Altiery54 or ebristol as both have used our kit and could speak to its numbers.
thanks alot for the info!! i have cai and catback so hopefully they will help. do you know how hard the install is i think the only problem i will have is getting my stock pully off. i am kinda worried about my stock clutch to.
my question is what all needs to be done when installed? meaning... does this thing have to be tuned? Im pretty sure it does. Looks like Ill be dropping the Stage 1 OTT system off to be installed then tuned on a dyno?
how have yall done yalls Stage I kits?
Obviously a custom tune is better. This canned tune is designed to run these mods on a complete stock exhaust/cooling car.
I had Josh tune it after he installed the parts. We put another degree of timing in it since it wasn't knocking at all. I'm at like 19*
im at 21.5-23 at the end of the powerband
i occasionally kr .5-2 tho
Ok good to know
the reason I'm asking is I can find someone to install this at my place. but if it HAS to be tuned right away then Im gonna have to find a shop that has the ability to install then tune the car.
ROGER THAT!
ROGER THAT!
Last edited by blackgloves; Nov 1, 2008 at 04:55 AM. Reason: Automerged Doublepost
this tune runs real rich. My friend has it on his redline. He is running full bolts with a h.e.
im runnin full bolt ons with gm stge 2.. my car pulls on his pretty good. so only way to get power out of this kit is to get it tuned with hp tuners afterwards
