OTTP H/E Installed still hot
Ok guys any ideas...The H/E is on and when the car at idle temps have gone as high as 205????????????....checked everything looks good have it running into the stock H/E first then into the OTTP H/E and then back to the water pump.
It might be possible that air bubbles are in the system would this cause high temps??
Any advance of anyone who experienced anything like this please help me out.
Thanks in advance RYAN
thats telling you how hot the coolant temperature in the radiator system is... so in theory this has nothing to do with the supercharger coolant system, infact blocking the main opening with the h/e would make it a tad hotter in theory
and open the hood and check the filler neck and check for coolant flow. if you see no flow then most likely your pump gave out. pump is located under the car, cant miss it.
Ok so how do I know what the temp is at the manifold just sent data back to trifecta last week with out the H/E on and Vince said the manifold temp was very hot up to 180 and was causing a slight knock???
yes manifold temp or iat, can be recorded during datalogging, something that the stock DIC will not monitor
umm... you plug it in, and it works
Yeah I did bleed the system but I am not sure if it worked right. As you can tell from above I am new to messing around and modding cars
I will look for flow in the filler neck was adding some coolant in there at the gas station with the engine running (Hope that was ok) and it flowed away
Well thanks for getting me in the right direction. Interceptor all hooked up and at WOT at the tops of third the hottest IAT2 is 156 does that sounds about right to you all
THANKS
THANKS
well, you are missing another piece of info, you need to compare your IAT against your IAT2's, what is your IAT temps?
30 or 40* difference between IAT and IAT2's is acceptable anything above thta will generally mean you have air or you ned to take a hammer to your pump.
