overheating..stuck..help!
Old Nov 22, 2011 | 07:17 PM
winning_blue's Avatar
been in stop as go traffic for as long as I can remember. then my CEL comes on for the first time ever, my coolant peaked at 230 when I finally pulled over. Now I'm sitting between 186-196..usually in the low 180's I believe. All levels look fine though?
Old Nov 22, 2011 | 07:22 PM
Gelladuga69's Avatar
Have you checked your intercooler pump?
Old Nov 22, 2011 | 07:23 PM
where's that located?
Old Nov 22, 2011 | 07:31 PM
Powell Race Parts's Avatar
that wont affect your engine coolant at all. check your fans are coming on ( relay, connectors etc) ...230 is not the end of the world, but it should not happen. sounds like fans not coming on, could be t stat, but get all the usual engine cooling system checks done and you will find the answer..
Old Nov 22, 2011 | 07:39 PM
my t stat does get stuck low sometimes..that shouldn't trigger the CEL though
Old Nov 22, 2011 | 07:47 PM
still have 130 miles til home..highest I should let it go before pulling off?
Old Nov 22, 2011 | 07:51 PM
nhanson's Avatar
230*
186-196 is normal temp.
Old Nov 22, 2011 | 08:38 PM
06cobalt racer's Avatar
really????
Old Nov 22, 2011 | 11:50 PM
UPDATE: made it home, killed an hour in the town I was in to let the traffic die down in DC/Baltimore so I wouldn't be constantly stopping and going.
When I was cruising on the highway, temps were completely normal (163-175) however the CEL is still on. Whenever I come to a stop or stay in first for a little, temps rise fairly quickly..got back up to 202 before I realized how to keep it low. Something clogged? Higher speeds are fine so that's why I'd think that.
Old Nov 23, 2011 | 01:39 AM
nhanson's Avatar
anything 220 and lower is normal
Old Nov 23, 2011 | 01:43 AM
FryLoch's Avatar
Yea my car in the warmer months frequently will hit 220+ it's just a shitty design from the factory I honestly don't know WTF they were thinking.
Old Nov 23, 2011 | 09:01 AM
mrbelvedere's Avatar
if you are only seeing 163-175 you need to replace your t stat check the fans to make sure they are working
your high
no its not a shitty design you more then likely have a problem
Old Nov 23, 2011 | 10:27 AM
nhanson's Avatar
If I wasn't tuned I saw 220 on a regular basis. It's normal
Old Nov 23, 2011 | 01:40 PM
Owen S's Avatar
I think I've only ever hit that once, and that was idling for a good 20 minutes without moving, on a hot day. Try turning on your AC in traffic, it'll get your fans going.
Old Nov 23, 2011 | 01:44 PM
outtamymind's Avatar
if your still having overheating issues, turn your heat on. it will kickstart the pump and allow for circulation. but as others have stated i would double check to make sure your fans are coming on.
Old Nov 23, 2011 | 04:06 PM
Leafydialupking's Avatar
How will turning the heat on kick start to pump? The pump is constantly driven by the crank with a chain. This is a simple thing to figure out, first your thermo is getting stuck open. Thats not causing over heating though. 2nd. Let the car sit an idle until it gets really hot again, check and see if the fan is running. If the fan is running, get in an rev the car to like 2500 and hold it there. If the temp goes down, then you know you have a water pump on the way out. And if the fans arent working, then well, check the fuse and relay.
Old Nov 23, 2011 | 06:21 PM
Owen S's Avatar
If I've learned anything about troubleshooting, check fuse before anything
Old Nov 23, 2011 | 08:10 PM
220 isent normal op temp for these cars if you are seeing 220 on a regular basis you got problems
Old Nov 23, 2011 | 09:20 PM
nhanson's Avatar
Its not normal if your on the freeway...but if your stop and go or beating on the car then its normal
i once saw 225 after being hard on it (was actuallly 220 when i shut it off)
Old Nov 23, 2011 | 10:49 PM
Sharkey's Avatar
220*f is nothing to worry about, from factory the fans hit 50% at 220 degrees. now, my car with stage 2 tune, sitting in traffic would generally hit around 215*f before it started coming back down, and it did that from new.
as for the problem, yes 230 is getting high. now being you temps drop when cruising down the freeway, id say your overheating problem is not caused by the thermostat (although with the temps you listed it sounds like it may be stuck open). check your fans, id bet they arent coming on. another thing to try is turn your a/c on, the fan should come on instantly. if the fans are working, check the water pump as listed above.
Old Nov 23, 2011 | 10:52 PM
Phyrric's Avatar
I broke 235+ with a broken IC pump at the track, no CEL or anything though.
Old Nov 23, 2011 | 10:55 PM
nhanson's Avatar
car doesnt touch over 200 now that im tuned
Old Nov 24, 2011 | 01:03 AM
I actually did turn the ac on when I was coming home and yes it did help drop the temp quite a bit. I don't beat on my car..at all so I never see 200's like you guys have stated. By beating I mean constantly to the floor like I've seen some of the guys around here do. In the shop now because they're gonna check a few more things on Friday. The shop owner had the car idle for 1 hour today and temps were completely normal and the CEL went off when I drove the car there an hour earlier and it was on? Beyond confused with this POS they call a cobalt.
Old Nov 24, 2011 | 01:39 PM
its an old school trick that when the coolant starts to overheat turning the heat on will actually get the coolant moving quicker allowing for the heat to dissapate.
i used to do it in my dad's old intrepid because it decided it wanted to overheat all the time. just turning on the heat would drop the coolant temp.
Old Nov 24, 2011 | 01:47 PM
nhanson's Avatar
it doesnt move it any faster...it just acts like a 2nd radiator
