Overkill???
Overkill???
is a magnaflow 3" racing series exhaust overkill for a cobalt around 280 whp. on the site they stated: "The Race Series is recommended for the serious racer, turbo, nitrous oxide fuel systems, or wild cam applications."
vortex header + cti downpipe +(racing series exhaust)?
wellim starting with a base= vortex header, cti downpipe exhaust and intake, but i plan to have the ottp stage kit with the stage 2 belt a 2.6 pulley, ls4 throttle body, and a 90/10 meth tuned
i doubt i'll hit 300, are you sure? im buying from magnaflow tmrw at 2 pm, so i need to know stats
why wont it be needed under 300 whp? i hear mixed reasons, how about some science for the newb?
You'e actuay close enough to 300 whp IF and I mean IF you hit 295WHP to run 3" and be able to justify it. You're best bet would be to dyno the car PRIOR to getting the exhaust to see exactly where you are so you can make the right decission on what your car needs.
Yes the 2.5 will be enough but if you're planning a future BIGGER upgrade then the 2.5 will become you're weak link. If I were you I'd wait till After I did the stage parts to get the exhaust. But if youabsolutly HAVE to get one then go with the 3" seeing you are planning more right around the corner. If this was where you were gonna stop modding or wanted to be then I'd say go with the 2.5. But like I said you ARE planning more so it makes no sence to limit yourself by the 2.5.
the mods that i listed to you are the end of the line, no more power mods after that, and im getting a deal on a specific muffler near by, a racing series for 2.5 or 3 inch for 200 after tax including the resonator.
Its velocity we are worried about, not back pressure.
2.5" at 250hp will have the exhaust flowing faster (which is better) than a 3" at 250hp.
You will see better improvements if you were to go 2.5".
